Question about Sylvania 6413TC 13" TV
Color Tv I have a 20 year old Sylvania TV in my bedroom. I don't use it a lot, but when I do, there is a low buzzing sound coming from the speaker. It does not seem to affect the audio, that sounds normal. Any ideas?? I have an electronics background, so I might be able to fix it myself, once I can narrow down the problem. Thanks, Greg.
  • gplesh99 Aug 11, 2008
    I believe your'e right, now that I think about it, it always has had a very low buzz, but seems to be getting louder with age. Oh well, 20 years old and still a great picture, it's far outlived most sets. Thanks!!!
  • 6,487 Answers
Try first to Mute the television and check if the buzzing sound will be gone , because if its gone that can be a problem with the sound part of your unit, but if the buzz is still there and the television is on mute, consider the buzz as a strange sound in one channel sio check if the buzz is still there when you switch channel .Sounds like wind blowing, or leaves rustling? That can be the wiring problem .
Hope that helps............
Posted on Aug 11, 2008
  • Sylvania Master
  • 19,396 Answers
Buzzing nois of this kind can come from a short or from disturbance.
  • Ginko
    Ginko Aug 11, 2008
    Check that you do not have any electric device near to the phone that can cause electric disturbance, such as a power adapter or a large appliance.
    Eventually move TV to a different place to check if the problem persist.
    If the buzz is not because of electric disturbance, then it can be a short on speaker cables inside tv, a short on audio area of TV pcb board, or a bad component on pcb, for example a faulty audio chipset or a burnt capacitor. In this last case, in order to fix the problem, the TV must be taken apart and component on board tested using multimeter.This job should be performed by a TV technician.
  • Sylvania Master
  • 13,433 Answers
Well im not sure what can be done about it, our tvs also have a little buzz in them, my laptop also has a background buzz very silent one, if I plug my headphones directly into my computer, I get the same buzz from there also, but when I plug my headphones into my lcd screen there is no buzz, there seems to be somekind of a filter or amp which filters the buzz out and the sound is clear.
this is not really a fix, but I feel the buzz is normal, I suppose it could be cleared out by somekind of a filter or amp between the source and the speaker.
  • Ekse Aug 11, 2008
    It may also be interference from other electronic devices around the television but since its in the bedroom I suppose you don't have many electronic devices in there, also bad signal might make it louder.
Sound won't work on my sylvania
If it has a damaged headphone jack this can cause this or if only one speaker it may be open (bad)---try putting ear right to speaker to see if any sound or buzz.
Loss of sound not common on this set or most newer sets.
Oct 15, 2012 | Sylvania Televison & Video
Hi! My toshiba 2100td tv is over 10 years old and last few years it's having weird problems. When it's turned completely off (not in standby) and when I turn it on, the screen blinks for a 10-
The real problem here is its age, a lot of these sets of that age critically needed parts are just no longer available.
I repair them but the real risk is someone fixed it, a few months later it develops another problem etc etc etc.
Ten years is now a days a long life for a TV.
Apr 16, 2012 | Televison & Video
I have a Samsung LN40 that is 3 plus years old. Last year the bezel started seperating form the rest of the body on the 2 upper cornors but the tv functioned. The seperations have increased and this week...
You have a lot going on with this tv. i'm guessing you did not buy it new is your bezel is coming apart. if it was just a picture problem I would have guess the t con or the lcd screen. but since youalso have sound problems my first guess would be your signal board. You would have to open up the tv and get the part number from the board itself to order it.
You can get get parts for this tv at www.interliquidparts.com
Jun 28, 2011 | Samsung LN40A650A LCD TV
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
I have a 3 year old lcd color 15" flat screen digital dolby mod. # lc200sl8 A the picture comes on but the whole picture is white you can see some color but very light I have tryed to darken it but won't...
I don't know if your set has a separate power supply but this sounds like the failure of a low-voltage circuit supplying power to the section which modulates the individual pixels on your display.
Sylvania is one of several names owned by Funai which is the worst of all Asian manufacturers.
Jun 26, 2010 | Sylvania LC-200SL8 TV
Hi! Simple question; answer hard to find. Does a Sylvania 6520FDF (20" color TV/DVD, purchased new in late 2006 or early 2007) need a digital converter box? Thanks for any assistance. Bruce
BRUCETYRE::
unless the information that comes with the tv says it is digital ready, NO!! and you will need a converter box.The reason is that for almost two years before the conversion, the /tv people knew what was going to happen and they were getting rid of the 'old' stock.The TV must say it is digital ready.
p.s. I looked it up for you...SORRY!!
"" The manufacturer has informed us that this model has been discontinued. However, it might still be available for sale.""
p.s.s. Now I know for sure that it is not digital ready...get the converter box.
Nov 30, 2008 | Sylvania 6520FDF 20" TV/DVD
Sylvania 6413TC 13" TV Logo
468 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
