Question about Fujitsu LifeBook T4210 Tablet PC
Video driver for WinXP
My laptop can not keep the resolution 1024x768, everytime i adjust, then restart, the resolution is always back to 1400x1050. Even i install the driver follow the laptop or download from internet. But no results.
When i change to use Win Vista, the display is ok.
Can you help me.
Thank you
  • cybercreed Aug 09, 2008
    For ginko: i download the driver from that site aldready. but its not work.
    Can you give me the other ways?
    Thank you
  • Fujitsu Master
  • 19,396 Answers
Click here to download from Fujitsu website. You will need to select your model and Windows version.
Posted on Aug 08, 2008
SOURCE:
Running extremely slow
Try restarting your tablet if it still is not working try restarting it again unstall a few apps download CM security app this should help speed up things on your tablet CM Security Antivirus AppLock Android Apps on Google Play if it keeps up try backing up your data on sd chip and factory reset your tablet good luck!!
Mar 16, 2015 | Samsung Galaxy Tab 3 7-inch, white
Nexus 7 tablet won't talk to XP computer
Hi, make sure that you have your Nexus screen on and passed any PIN or authentication screens, in other words, log in to it.
Then you should see the main directory on the shared drive.
Keep in mind that WinXP support has ended last year and vendors do not keep their drivers up to date for this anymore. So there might be problems.
Apr 15, 2014 | Google Nexus 7
My lenovo s820 keeps on restarting
The first thing to do is boot it in safe mode and let it go to sleep, then wake it up and see if the problem goes away, If it does then the problem is related to something in the startup programs.
Feb 03, 2014 | Lenovo S820 Android 4.2 MTK6589 Quad-core...
Asus tf101 only half screen showing
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Jun 22, 2012 | ASUS Eee Pad TF101B1 Tablet
What is the combination of keys (shortcut) to change the screen resolution (not orientation).
There is no Fn-Fx key combination to change screen resolution (at leat on my R10 running Windows XP. Even if you create a shortcut to open the graphics properties you still have to open the relevant tab manually to change resolutions.
You can open the Intel Extreme Graphics 2 for mobile icon on the tray, go to the graphic properties change the resolution and save as a scheme. With a customized scheme defined you will be able to click the Intel Graphic properties and select that scheme. But be careful, your tablet pen will no longer be calibrated with the available screen area.
I tried on my R10 (native resolution 1024x768) and all I could select was [email protected] 60Hz.
Feb 23, 2011 | Toshiba Satellite R10 Tablet PC
So I reinstalled the Windows XP. The change resolution button doesn't work, it just show you modes to choose and nothing else. I'm trying to change the resolution, but nothing happens. I can't even change...
XP is an obsolete operating systems. There is no support for it. Vista, Windows 7 and 8 have passed you by. You should be on Windows 10.
Resolution comes from your video card. You need the software and drivers for it if you can find it. Windows XP will only give you basic generic VGA Drivers.
Nov 28, 2017 | Samsung Q1 Ultra - EL Tablet PC
Bad Display
The usual symptoms of the ati2dvag problem are:
  • PC crashes without warning, sometimes the display shows weird patterns before the crash.
  • Resolution may revert to the lowest resolution settings upon restarting your PC.
  • The CPU temperature may shoot up prior to crashing.
  • PC may not be able to reboot back after the crash, unless you turn off the power supply unit of your PC and switch it back on again.
  • Your PC tells you (sometimes only) that the ati2dvag driver has failed to function.
This is a universal problem afflicting thousands of PCs worldwide and can occur in totally new or old computers; it doesn’t discriminate. Imagine the frustration of buying a new PC only to have it crash on you after a few weeks and thereafter.
There have been many hypothesis’ postulated. Some say it is a very stealthy virus, some say it is an incompatibility with Windows XP SP2 and ATI, some say it is a problem with the hardware acceleration settings in the ATI graphic card, others say it is a problem within Windows XP itself…etc.
The 2 most common “solutions” are:
  • Reinstall the ATI driver. You are advised to launch Windows in Safe Mode (press F8 before Windows boots), go to Windows Add/Remove programs and uninstall everything ATI. Remove the DAO/MDAC component as well. You can use the ATI removal tool utility which can be downloaded from the ATI website. The complete set of instructions on removing ATI can be found on the ATI website.
  • Go to System Devices in My Computer > Properties > Hardware, and locate the option, PCI standard PCI-to-PCI bridge. This could under other names on your PC, so contact your PC vendor if you’re unsure. Right click, and select the “update driver” option. Manually search and install the PCI standard PCI-to-PCI bridge.
Jan 12, 2010 | Gateway CX200S Tablet PC
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
My Screen!!!
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Mar 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Fujitsu LifeBook T4210 Tablet PC Logo
130 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Rachid Mekrob
Rachid Mekrob
Level 1 Expert
Tony Raia
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
