Question about Dell Inspiron 6000 Notebook
Dell Inspiron 6000, charging AC problems
I replaced the battery and adapter. I had been getting messages that the adapter wasn't properr (it was supplied by Dell). No changes occurred. I still get the message; the computer doesn't stay on AC power, unless I fiddle with the adapter at the computer.
Many Thanks.
Mike
    Genius:
  • 2,028 Answers
This sounds as if the jack in the machine is loose or broken. Take a small screwdriver, place it in the jack, and see if there is any play in the jack. If there is play then you know the jack is loose/broken. I would suggest checking it or having someone check it. A loose or broken jack can create an electrical arch that can do severe damage to the machine, so if it is the jack, you will want to get it fixed ASAP. I also suggest not using the machine, if possible, until the jack is checked out. If it turns out not to be the jack, then it's going to be a problem with the power management system, and this is a major fix. From what you've posted, I'm going to say that it's the jack, and repairing the jack will fix your problem. If you have anymore questions feel free to ask.
Posted on Aug 08, 2008
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
I hv got a replacement battery for dell inspiron 6000. But it is not charging at all. Can you help me out to install the battery? thnx
Remove & Press Battery Indicator .If OK update the BIOS, get it from Dell Support. If no good, check Battery Info in BIOS. If AC Adapter incorrect, you need to replace it.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jun 26, 2010 | Dell Inspiron 6000 Notebook
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 not charging
suspected faulty battery. replace the battery.
May 28, 2009 | Dell Inspiron 1501 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Power issue
Is the new power supply a Dell. Some aftermarket power supplies, especially Targus, will not charge the battery in a Dell. If it is a Dell supply, then it's one of two things. 1- the battery is shot and needs replacing. 2- the power management chip on the motherboard is shot and the motherboard needs replacing. If the battery light is flashing orange then the battery is shot. If the battery light is green, then go into the power settings and see if the machine shows that it is charging. If it doesn't show that it's charging then it's the pm chip.
Jun 16, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
105 people viewed this question
Alun Cox
