Question about Dometic Rooftop RV Air Conditioner
Compressor not kicking on
It seems the fan runs yet the compressor is not kicking on and no cold air
They said there is a fuse which we cannot locate It is a ducted system
  • ljd137 Aug 11, 2008
    yes i have that problem..i tried circ break; fuse..both good...check power and that was good too..dont know what else todo.. duo ac rooftop.please help
  • donna331 Aug 15, 2008
    we had an heating & air conditioner guy come look at it
    there is a plug on top that must plug into the compressor that came un pluged
    It seems to be working now
  • Dometic Master
  • 6,674 Answers
What type of thermostat are you using? When was the last time it worked ? Do you just get fan on cool mode, or does fan only run on fan mode?
Posted on Aug 14, 2008
  • Mike Butler
    Mike Butler Aug 15, 2008
    Does your furnace run off same thermostat, and does it work ?
    Do you hear any clicking noise from AC when switching to cool?
    When did it last work?
AC Compressor running but no cold air?
If no air is coming out, the blower fan is not coming on. Find the blower fan, follow the wires back from the blower motor to a plug, unplug it, set it so the blower should be on, check for voltage across the plug. If there's about 12 volts, but the blower doesn't make any noise when you plug it back in, the motor has a problem (mine once quit like that because a moth got into it). If it buzzes, etc. the fan may be jammed.
Jul 26, 2017 | Honda Cars & Trucks
Samsung fridge SR-L628EV, compressor works, all fans works but no cold air at all, it has been setting for two years but now is not giving cold air, any idea on how to fix it? Thank you
either needs freon [compressor will come on if low freon ] interior fan ,compressor internal valve damage tx valve damage condenser fan -etc can be anything with compressor running feel and look at condenser coils they should be hot and be careful of fan if not hot more than likely need freon
Sep 04, 2016 | Refrigerators
KF9000e. Why does compressor cycle at short intervals?
Yes. due to low rpm of fan motor in the condensor copil. or dirty condensor coil. I If so, replace fan capacitor.
If all good, check the seating of condensor set. It needs minimum 2mtrs open space for air throw. If not due to overheat compressor gets short cycling on and off.
Sep 07, 2015 | Amcor Heating & Cooling
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Air compressor does not kick in unless ambient temp is > 80
Do not operate low fan and maximum temperature as the coils will freeze up stopping air flow.
May 21, 2009 | Whirlpool Electronic Window Air...
NO COLD AIR
If the fan and compressor are both running and no cold air then you’re low on refrigerant,
Thermostatic expansion valve closed or bad , dirty condenser or the valves are bad in the
compressor.
Apr 25, 2009 | Haier HWR10XC3 Air Conditioner
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
463 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
