Question about Black & Decker String Trimmer Cordless 12" 18V
How to feed line into a black and decker trimer/edger model st6000 electric?
    New Friend:
The ST6000 uses centrifugal force. Once you mount the new spool of string and thread it out of the feeder and into the housing below, plug it in, give it power and hold the line feed button down, feeding the line. Within seconds, the line will feed out through the head and you'll be in business.
Posted on May 02, 2010
SOURCE:
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
Jun 14, 2015 | Black & Decker Black and Decker & Grass...
Where can I download black & decker st6000 owners manual
Couldn't find one. Might this one serve?
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0CDIQFjACahUKEwi3s7mfpIvGAhVRMowKHbmUAP0&url=http%3A%2F%2Fwww.ehow.com%2Fhow_7484314_thread-black-decker-st6000.html&ei=wWd7VffOFtHksAS5qYLoDw&usg=AFQjCNFL3IyFWdUOOtb62OxVuFd6dzbi7Q&sig2=mPBwzo9n_QxBGoVh_P5efg&bvm=bv.95515949,d.cWc
Jun 12, 2015 | Black & Decker Garden
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Jul 08, 2011 | Black & Decker String Trimmer Cordless 12"...
My black and decker st6000 is not popping out the string to edge it is a touch feed when popping to start it won't bring out the string HELP!
I have a touch feed trimmer also. I've found that when the string doesn't come out, there is usually a twist in the line inside on the bobbin. Open it up and see if the line needs to be straightened out. Sometimes I've had to rewind for a bit.
Before you do that, be sure you are bumping it hard enough. Mine needs to bumped on a pretty solid surface.
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 | Black & Decker Garden
My auto line feeder won't stop feeding line out. any suggestions?
Rewind your line the opposite direction you wound it on this last time.
If it is wound in the wrong direction, it will continue to feed out while running and that is your problem.
I hope this helped,
Please Rate Me
May 04, 2010 | Black & Decker Black and Decker & Grass...
How do I add new string to my black and decker st6000
Home Depot have the string for the black and decker weed eater
Aug 25, 2009 | Black & Decker String Trimmer Cordless 12"...
Feeds line almost constantly
There is a recall on the head units on some of the electric trimmer models,I dont know all the details but one recall is for the head unit actually flying apart. I thought I would tell you,I would contact black and decker and see if yours is one of the recalls.
Aug 10, 2009 | Black & Decker 14" Grass Hog Xp...
Corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
1,238 people viewed this question
Top Black & Decker Garden Experts
gggg
Nick Olsen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
