Nokia N91 Cellular Phone Logo
Posted on Apr 17, 2011
My nokia n91 can't browse websites. even in wlan.. and gprs. the 3g display have a disconnect logo (two arrow pointing in opposite direction) below of it and i cant remove it..pls help.. [email protected]
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
50
Points
6
You need to go into phone settings menu, find connections or active connections, then you will have options to turn some of setting on or off. try this should work.
How to get free internet in nokia n95?
Hi, To connect your Nokia N95 to the internet please follow this steps:
1. Open the main menu and then select on Tools.
2. Search for WLAN wizard and press the center key to open the wizard.
3. The WLAN wizard opens to show you active WLAN's in the area. Now, for you to access the internet, highlight the name of the network you want to connect with and then click on Options and then select Start Web Browsing.
4. Please enter the password if required as shown below, and you are now ready to start browsing the web.
I hope this helps.
Thanks for using FixYa.
2answers
What does the letter G being displayed on my Nokia 2730 mean?
That logo is a GPRS if you have that you can browse internet . But you need a load to access different website
2helpful
Right now i m using NOKIA C5 handset with BSNL 3G sim.. i wanted to access internet with this. I m not able to get settings for internet access.
http://125.21.241.77/wap/smslive/Free-Download.php
or else
Activate GPRS by sending GPRS PRE to 53733.
3. GPRS will be activated within 24 hours. After the GPRS is activated call the customer care for the GPRS settings.
4. Setup your phone according to the settings given by BSNL's Customer Care.
5. Now do a e-Recharge with Rs.230, or whatever unlimited plan exists in your area.
6. Go to your mobile phones network settings and select Dual Mode or UMTS as your Network Mode. In Nokia Mobiles, you can find this setting under Tools > Settings > Phone > Network> Network Mode.
7. Search for BSNL 3G signals, you will see a 3G logo near the network name. Set it as default.
8. That's it now you can surf the Internet at 3G speeds. You will get near about 500kbps to 1200 kbps speed.
Note: Use BSNLEGPRS or BSNLPREPAID as your Access Point.
1helpful
My X3 will not get connected to WiFi. The AP is listed usable, internet connection is automatic and eventough I force connection (by pressing long the AP identity in saved WLAN networks menu) and the wlan...
Are you positive that the connection is not going through your Wifi??
I have an HTV Evo and when I am connecting to the internet through the Wifi, my 3g will show up regardless.
Thanks
4helpful
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
I cant get internet on my n97 nokia phone so i want you to help me with that.
Hi
Check the priority of your internet connection access points under settings>connectivity>destinations. By default the WLAN gets higher priority. Therefore, when there is a known WLAN available, the phone will connect through it before any GPRS or 3G connection.
Also, there are some reports of conflict between the WLAN & GPRS/3G connection & the web browser gets this conflict & present the "Invalid server name". The solution of this is to close your browser & restart your phone. Also, removing your WLAN, GPRS, or 3G setting & redefining them may help.
Good luck.
10helpful
4answers
I want all secret code all nokia n72
On the main screen type
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# – Display the MAC address of the WLAN adapter. This is available only in the newer devices that
support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# – takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair – if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# – Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
#3370 – (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# – Half Rate Codec activation.
#4720 – Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
How to cnnect my to browse
register the GPRS then you'll receive message setting till the GPRS is active. after that, press 0 about 3-5 second till the logo of GPRS appear. now you can start to browse.
2answers
Unknown letter in the display
'G' stands for GPRS. Just check if your GPRS is activated or not. It is shown only when GPRS service is active. You can deactivated it through contacting your cellular service provider.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
