Question about Mitsubishi Televison & Video
I need the three-digit manfacturer's code for a Mitsubishi model HS-U56 VCR.
  • 3 more comments
  • gualalazr1 Aug 08, 2008
    Neither code 011 or 051 solved my problem. I am trying to record a program from Dish Network and those codes do not enable my Dish receiver to find the VCR.
    Dish says that the code 761 is not in their database.
    I have wasted $9.99, since codes 255 and 258 do not exist either. If only I could contact the manufacturer. They apparently are the only one with the correct answer.
    I give up! Thanks anyway.
    Somewhere the nature of my problem has been lost. I am not trying to program a remote control device. I wish to record a Dish Network TV program to a VCR, but Dish cannot locate the VCR without the manufacturer's three-digit code, which it says I could find in the VCR user manual. There is no such code in the user manual.
    Genius:
  • 1,665 Answers
Original remote HSU56
Replacement remote RC5002
see link
Posted on Aug 08, 2008
  • Mitsubishi Master
  • 13,434 Answers
I see you didn't get your problem solved, [email protected] for a refund.
    Genius:
  • 1,011 Answers
Sir,
call this number and get the code
call 24 hours
1-866-728-8812
thanks
good luck
  • 2,071 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 10, 2008
    yourbrand is not listed, and you are still not able to get the unit to respond,
    trythe following procedure to search for your code.
    youreach the end of all the codes for this device type.
      the remote)
    4. ALTERNATE slowly
      POWER)
    2. Learn the buttons from the original
    Line up your original remote and the head-to-head before completing
    thefollowing steps.
    1. PRESS and HOLD the SETUP
      button until the red LED flashes twice.
    2. PRESS 9 - 7 - 5, the red LED
      will flash twice.
    3. PRESS the DEVICE key where
      you wish to learn the function. The next 3 steps must be completed within
      10 seconds.
    4. PRESS the button that will
      receive the learned function, the LED will flash rapidly.
    5. PRESS the button on the
      original remote to be learned.
    Now you can repeat steps 3 through 5 to learn other functions onto other keysor
    press and hold SETUP until the Cinema's red light flashes twice to lock inyour
    new feature. (If the red light does not blink twice, stop and repeat
    stepsthrough 6).
    To test the new feature, press and release the device key in which the
    newfeature was learned followed by the key on which the feature was learned
    More help for programming your remote can be found here:
    http://www.hifi-remote.com/manuals/ofa-l...
    Hope that helps! Should you have any further questions,please feel free to post
    them here.
    Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model
    (optional):
    We could not find an exact
    match, we think this code will work. 10054 Setup
    Instructions
    · Set the "Mode Switch" to TV.
    · Press and hold the "Mute" button
    and the "Select" button until the visible LED blinks twice.
    · Enter the 5 digit Code above.
    · Try your new code and tell us how it worked!
    You'll have to settle for that, use the middle power key in
    the tv device to power on & off the tv.
    hope this may help;
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 21, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • 6,487 Answers
Try 994, 652 and 136
  • Mark Gil
    Mark Gil Aug 08, 2008
    If none of those codes work better yet call Mitsubishi and hopefully they can provide you the correct code this is the number 800. 332.2119..
  • 813 Answers
Reset on factory setting
    Guru:
  • 147 Answers
I believe the codes 255 and 258 will work. Please let me know if this helps.
Good luck and take care,
Chimpster
  • Alexander Kogl Aug 08, 2008
    Your best bet is to just have 2 remotes. The universal one you use with DISH NETWORK, and the regular old VCR remote.
    To date, I've never heard of a universal remote with 100% compatibility to all electronics.
    For example, say you get an iPhone while using T-Mobile's cellular service. Later on you decide to switch to Sprint, but can't use the iPhone. Why? Its just not compatible.
    Take care,
    Chimpster
    Genius:
  • 2,035 Answers
Try : 761
  • Anand Kumar
    Anand Kumar Aug 08, 2008
    If you have tried all the manufacturer's codes on a particular
    device, but the remote will not respond, you can identify
    the correct code using your remote control.
  • Turn on the device.
  • Press and hold a mode key for three seconds
    until the four mode keys flash twice. The selected mode
    key will continue to flash.
  • Press POWER. The mode key will stop flashing,
    but remain on.
  • Point the remote control at the device.
  • Press and release the Cursor Up key slowly
    and repeatedly. Each time you press the key, the remote
    sends the power off command to the device using a different
    device code. When the device turns off, the remote is
    programmed with the code that controls that device.
  • Test whether other functions work using
    the remote. If a primary function does not work, continue
    to press the Cursor Up key to find another code that turns
    off the device. Then test the functions again.
  • When you are satisfied that all primary
    functions are working, press OK to lock in the code. Use
    the mode keys to switch control to a device. The four
    mode keys light to indicate which device is being controlled.
    Brigadier General:
  • 3,614 Answers
011, 051
  • micromaster
    micromaster Aug 08, 2008
    this is the another set of codes.
    Mitsubishi
    062, 067, 068, 069, 070, 071, 109
  • micromaster
  • Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
  • Use the number pad buttons to enter the three-digit number corresponding to the equipment (click here to view remote codes). The light will blink off after each digit is entered and then return to a steady light.
  • Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment.
  • For remotes that have one Mode button at the top:
    If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over.
    • With the desired equipment on, press and release the Mode button until the light flashes behind the correct mode.
    • Using the tip of a pen or the eraser on a pencil, press the address button.
    • Enter the code (see links to find your code below) on the remote's numbered keypad for the equipment.
    • Press the Address button. If the code entered is valid for the remote, the mode light flashes three times.
    • To verify the code works, try several functions for that equipment. Some codes may provide partial functions or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
SOURCE:
Codes for a mitsubishi vcr on a chunghop universal remote control
Depends entirely on the model # of both the remote and the TV. You can probably get that code from either website, but you'll need the model #'s.
Jul 28, 2017 | Mitsubishi Televison & Video
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
Need remote code for mitsubishi vcr
Need remote control for Mitsubishi HS-820V(IR) VHS recorder,any idea where I might get one
Regards
Vincent
Sep 13, 2009 | Mitsubishi Televison & Video
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Mar 30, 2009 | Mitsubishi HS-U560 VHS VCR
Need a substitute remote for mitsubishi hs-u431
If you go to www.remotes.com you can order an original replacement for your unit!
Please rate my response
Thank
You!
Jan 11, 2009 | Mitsubishi HS-U431 VHS VCR
Televison & Video Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
