Question about Sharp Office Equipment & Supplies
I replaced the cartridge on my Sharp UX-B750 inkje fax machine and it is giving me a message on the display to change cartridge and will not let me perform any other function.
    Master:
  • 521 Answers
Either the cartridge is not properly installed or check whether it is of same cartridge number as before of old cartridge or try to clean the brown dotted circuit of your printer and cartridge through moist tissue very carefully, or the replaced cartridge may be faulty.
Posted on Aug 08, 2008
HOW DO I CHANGE THE PHONE NUMBER ON MY FAX MACHINE
go to menu setting there you can see factory default select and press .then machine will reset as factory default.off machine and on it again it will ask time ,date your fax address fax number everything give it.
Aug 01, 2010 | Sharp UX-B750 Inkjet Fax
Said that cartridge was empty after changing cartridge,got that cleared and now it will not receive a fax. What do I need to do
Your faxes are probably stored in memory. They automatically print when the a) cartridge is installed properly full, b) fax has paper, c) there is no paper jam.
There also may be a "Print Hold" function activated.
1. Press <print hold> [RCV DATA PRINT] will display.
2. Press "Right Arrow" on the <start/memory> button.
3. Enter 4-digit Print Hold code.
4. Press <start/memory>. Printing will begin. If the wrong code is entered [WRONG CODE] will display. Go back to step 3 and start again. Once you've entered the wrong code 3 times, you will return to your standby display.
Mar 25, 2010 | Sharp UX-B750 Inkjet Fax
Install a refill UX-B750 cartridge but display still showing out of ink.
The machine is not identifying the cartridge properly. Attempt to reinstall the cartridge. It just may be installed incorrectly.
Dec 09, 2009 | Sharp UX-B750 Inkjet Fax
Sharp UX-B750 won't automatically answer calls.
Your reception mode is set to TEL/FAX or TEL mode, to set it to automatically receive faxes it should be set to FAX. Look at the LCD display ( right section ).
To change the reception mode you can print the HELP LIST by pressing COPY/HELP button.
May 26, 2009 | Sharp UX-B750 Inkjet Fax
Fax keeps saying out of ink
You can also put the machine in serves mode by unplugging the power from the machine, press both the the copy/help and the stop buttons at the same time, hold them and plug back the power until you see TF662B service mode.This also works well with refill cartridges. YJ
Feb 05, 2009 | Sharp UX-B750 Inkjet Fax
NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Jan 09, 2009 | Sharp UX-B750 Inkjet Fax
Refilled cartridge problem
There's some kind of a chip chip in the catridge that notifies the printer that the same cartridge has been refilled. to get around this check keep atleast 2 or 3 empty cartridges, refill and cycle them. That should do the trick!
Dec 02, 2008 | Sharp UX-B750 Inkjet Fax
SHARP UX-B750 facsimile will not receive faxes and displays the message "NO SERVICE".
Plug a regular phone into the wall jack and listen for a dial tone.
Make sure you are plugged into the LINE port of your fax machine.
Do you have DSL phone service?
Oct 21, 2008 | Office Equipment & Supplies
Out of Ink
Did you get any help with this issue? My machine is giving me a "cartridge error"...I can't seem to get it fixed.
May 15, 2008 | Sharp UX-B750 Inkjet Fax
61 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
