Question about Zenith Z50PX2D 50 in. Plasma HDTV
Zenith Projection Tv Set Model number ZB4685T no Visual
Hello I have model number ZB4685T of the projection tv sets and I have a problem...my tv will turn on, I'll hear the audio just fine and then the video will show for a min or two, fade, and then the screen will go black. I know I have power because I can hear the audio crystal clear just no video whatsoever. Anyone have any idea what might be wrong and how to fix it? Also with it being such an OLD tv set didn't know if anyone had any suggestions of places to find possible parts for the tv set. Thanks
  • jennyferbean Aug 08, 2008
    ok so what happens is when i first turn the tv it will be really light almost white and then it will turn to the normal shade and then all of a sudden go black. All of this happens within 5 minutes tops.
  • 4,234 Answers
Since this is a CRT based set, there could be a number of problems. What exactly do you mean when you say that the picture fades? Do you loose contrast and the picture gets lighter? or does the picture darken toward black?
Parts are still available, so this can be fixed. If youfeel you want to attempt this yourself, please supply additional info and we'll walk down the diagnosis path.
Dan
Posted on Aug 08, 2008
  • ABRsvcs Aug 09, 2008
    Thanks for the update. I will look up the part numbers etc of the likely defective pars and update this shortly.
    Stay tuned...
    Dan
SOURCE:
No picture
Your sweep module has gone out. Probably be lucky if can find part for this set.
Sep 08, 2009 | Zenith IQA56M98W 56 in. Rear Projection...
Have visual problem with tv
The convergence ICs have failed. Post the model number of your set and I will post the correct Ics for your model.
May 24, 2009 | Televison & Video
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Zenith projection tv model number r50w46
I read in the manual that you can turn the speakers off using the menu command when you connect up an external stereo system. You might want to check if this menu command inadvertantly was set to off. good luck
Jun 17, 2008 | Zenith R50W46 50" Rear Projection...
Zenith e44w46lcd
hi there,
what is model/maker of your DVD player, and also the TV you have there..
thank you
May 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
I would need the model number of your set to even begin to help you with your problem. Please post the model number and I should be able to help you out with it.
May 11, 2008 | Televison & Video
Zenith rear projection tv 56"
The convergence is way off. You may be able to adjust it thru a service mode menu. You'd need to get the model number first.
How old is the set?
Thanks,
SF in Vermont
Jan 29, 2008 | Zenith IQB50M90W 50" Rear Projection...
Code
try using a code listed under Hitachi brand name, believe set is made by hitachi on this model.
Apr 14, 2007 | Zenith IQB50M90W 50" Rear Projection...
R57w46 zenith
Hello Was wondering if you ever found anything out how to reset the IC Screen Numbers or what the factory numbers all are on the Zenith Rear Projection TV Model # R57W46? I have the same problem ! My 2 year old son, not knowing how he did it cuze only a technecian is suppose to get into this screen, but he did change numbers in the too. I called zenith themselves and no luck ! My screen is bowed , etc.. Any Help ?
Jan 16, 2007 | Zenith R57W46 57" Rear Projection...
Zenith Z50PX2D 50 in. Plasma HDTV Logo
132 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
