Question about GE (PSS26MSRSS) Side by Side Refrigerator
Door doesn't stay closed, hangs uneven
What is the part that is like a washer at the bottom of the door to support & keep it even?
  • abarkan Aug 09, 2008
    Yes. missing that black neoprene whatever - how do you get the door off?
I'm trying to fix mine. I did find a little part when it came out - a orange color - it appears to need some kind of neoprene washer - but I can't get the door off.....
Posted on Aug 09, 2008
Door repairs
The doors have a pin and washers that help keep the door functioning right. There is a kit they sell at your local auto parts store for about 10. bucks with new washers and a pin. More than likely the washers are broken and need to be replaced. Its a fairly easy job. Just cut off the clamp at the bottom of the pin push it out and placethe old washers with new washers then place in the new pin with the c clamp at the end.
Jan 26, 2013 | 1991 Ford Thunderbird
I have a Frigidaire washer model ftf2140fs1, the door doesn't stay closed and if it's closed it's not washing but all the buttons light up but the door lock light doesn't turn on. please...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Frigidaire ATF6000ES Front Load Washer
Refrigerator door will not stay closed
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Sep 25, 2009 | Sub-Zero Bottom Freezer Refrigerator
Door won't stay shut Have to remove the bottom shelf on the door to get the door to stay closed
To replace
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 30, 2009 | Refrigerators
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Our fridge door won't close properly
The door hinges have nylon bushings/washers to help them work smoothly. If the unit is very old and had a lot of use (like a large family) the bushings or washers could be just worn away. This also is indicated if the doors seem to be misaligned. If the doors don't seem out of place, it could just be that the unit is not sitting on a level surface, causing the box to twist and the doors th therefore bind.
Other possibilities: The door is burdened heavily with the milk, juices, food, etc. and therefore is just plain heavy. You have a "water-thru-the-door" unit and some leak has occurred to fill the door and it's insulation with water. (eww!)
Check to see that the surface is level, and that the door fits correctly. Make replacements or adjustments as necessary. Lighten the load on the door, or fix the leak.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 18, 2008 | Kenmore Refrigerators
Door not closing properly.
take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
Mar 31, 2007 | Hotpoint RLA80 Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
83 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
