SOURCE: torque setting
The sprocket nut torque setting is 132Nm. If you are after the plastic cover torque settings, i dont think they have one. Hope this helps.
SOURCE: my tiger 1050 wont start, plenty of power in
I would first fill the tank with fresh fuel especialy if the bike has stood for any length of time also determine as to wether or not fuel is actualy reaching the barrrels remove the spark plugs & check if they are wet or dry if they are found to be dry open the drain plugs on the carby float bowls if fuel runs out of the drain it must be asumed that your broblemis carburation & will require the carbies to be removed stripped & cleaned this will involve the removal of all the jets the float & the needle & seat once these have all bean cleaned thoroughly [compressed air is usefull for this part of the operation] &reasembled return them to the machine &
SOURCE: '04 Triumph Tiger clutch cable
If it is running alone the back bone then yes you will have to remove the tank.
