Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Change flex or housing - Motorola Mobility MOTOKRZR K1 Cellular Phone
Good Luck, Dee
Posted on Aug 11, 2008
Knocking noise after replacing automatic transmission in 98 ford escort zx2 4cylinder
Three most likely causes are: #1 You forgot to tighten up all the torque converter to flex plate nuts/bolts. #2 You cracked the flex plate during the transmission change. #3 You forgot to swap one or both of the alignment dowels from the old transmission to the new one during the change. These are hollow dowel pins. They go between the bell housing of the transmission and the engine block. Failure to have both dowels in place will lead to the flex plate cracking [see #2]
Mar 10, 2015 | 1998 Ford Escort
I'm changing the timing belt and i don't
The ring gear is part of the flex plate that the torque converter is bolted to. Remove the dist plate on the transmission bel housing to access it.
Jun 26, 2011 | 1989 Peugeot 505
My home button in my psp doesn't work
If you know how to remove the front housing of your PSP then we can surely identify why your HOME button is not working coz its either the FLEX or just the BUTTON itself, so we just need to verify which one is not working.
You can click HERE to follow the Steps on how to remove the Front housing of you PSP.
1. When your done removing the housing then remove the button and press the FLEX that corresponds with your HOME button, if it works then the BUTTON is the problem if not then its the FLEX
NOTE: By removing the housing of your PSP void you warranty. So if your not sure on what your doing ask assistance from Sony.
But basically its just a FLEX or the BUTTON.
Your feedback is greatly appreacited. Thank you for using FIXYA.
Apr 25, 2011 | Sony PlayStation Portable (PSP) Console
How do I change the water pump impeller on a mercury 7.5hp outboard?
get the kit from boat shop all it takes is four bolts and remove the lower housing.. when you put the impeller in... flex the blade the same way take a photo before you take it apart...inside get a new gasket for between the upper and lower housing too...
Apr 05, 2010 | Boating
How do you replace an LCD screen on Nokia E66
Undo 6 screws on back of rear housing, [2 near sim reader, rest on body .] When back pops off , be careful to release Sim flex , as it will tear easily. Disconnect main flex between 2 halves of phone.Remove main board , then undo 2 small screws at the top of phone .This will release the front housing. The LCD JUST FLIPS OFF THE CONNECTOR ON THE FRONT FLEX, be gentle with the handset and removal! . To rebuild , just repeat in reverse, as is quite simple, but BE GENTLE!!
Sep 15, 2009 | Nokia E66 Smartphone
your screen dosnt display anything?I am not quite sure what your asking but ill take a crack at it changed the housing and when you put the phone back together the lcd stoped working,if this is the case you either disconnected your lcd or you damaged the flex cable to the lcd,either way you need to open your phone back up just the top part where the lcd is,you should beable to see the flex cable coming from the phone to the lcd if it looks connected disconect and reconnect and try it if this does not work you may need a new flex cable wich means that you may have to get a whole new keypad cause the flex cable usually only disconnects from one side,well good luck
Sep 23, 2008 | Nokia 6131 Cellular Phone
Sony Ericsson W300i Removing the Housing
The housing is difficult to do. You have to be careful to not rip the flex cable that connects the two pieces. Once you remove the orange button on the side you will see a blue circular type pin. You must push that in all the way while gradually pulling your phone apart. Also at the same time you want to watch to make sure the flex cable don't snag itself of the folding parts. It slides in one way and you must be careful to not rip it. It is kind of in an S shape and slides in very delicately. once you get this part then the rest is easy to do. I hope this helps some and good luck. And yes I do repair these and replace all the parts on these phones so I know how difficult it can be for the first time. If you have anymore questions or if you want me to elaborate more on this just let me know.
Dec 08, 2007 | Sony Ericsson W300 Cellular Phone
Found this on Howard Forums. Sorry no photos.
Take off your battery, unscrew the screws on the back of the phone with a T6 screw driver.
Pry off the back plate,lift up circuit board gently(be mindful of flex cable) remove the flex cable from mail board by lifting brown part by the connector,
Unscrew then next 2 set of screws(be careful of flex cable!) remove the LCD board from the faceplate.
Now put the LCD Panel into the new faceplate. Find the new back slide and put your sliding rails on.(you may also put the slide magnets on from the old housing) carefully thread your flex cable through the opening.
Snap the Back slider on and then screw in the screws, then take the keypad housing and screw it into the slide rails.
Reconnect the flex cable by putting the brown hatch up(gently with finger nail) gently feeding the cable into the connector until the white line is about to the end of the connector.
Then put the brown thing down and apply little pressure.
Put the mail circuit board back into the phone with the headset jack going in first.
Then snap it back into place.
Transfer your speaker over the the new back housing with the prongs facing up.
Then screw on the back housing.
Replace battery and your DONE!!!
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
