Question about Frigidaire FRS26R4A Side by Side Refrigerator
Broken water paddle
I do not see any screws to remove the plastic to remove the broken water paddle.
  • 725 Answers
Be sure to unplug the refrigerator.
remove the drip tray by sliding it forward.. then remove two screws . slide the dispencer cover up two screw hold in the control remove water line two screws hold in water paddle. remove paddle and wire.
to replace water line use a long screw driver to push back into cover. make sure it extends bellow outlet..
hope it helps
Posted on Aug 10, 2008
How do you remove the panel covering the water and ice dispensers in an older Kitchen Aid 48 Superba side by side refrigerator freezer? I need to replace the water microswitch.
On the bottom of the bezel around the dispenser you will find 2 very thin slots. You push in a flat blade pocket screw driver and pry it up then lift the bezel up and off. Now look at the switch. It should have one mounting screw and a plastic pin sticking through the other mounting hole in the switch body. I'll bet that pin is broken and the switch is not making contact with the dispenser paddle. If it is broken you'll have to order that back plate . there may be nothing wrong with the switch. If the plastic pin is there, then the switch is indeed bad.
Aug 14, 2016 | Refrigerators
Fisher paykel DD609 diswasher - top draw does not drain properly. Water build up in bottom of the top draw even when bottom draw is used.
It is usually due to a small piece of broken glass or plastic blocking the little propellor that pumps the water out, (think of the little paddle in Nemo's tank)
You need to remove the bottom of the machine, undo one screw and twist the pump free, fairly easy, but make sure you turn the power off first. The outlet hose and pump will then be accessible, have a look in and turn the paddle with a screwdriver, bet you will find something blocking it. Shake it out and reassemble
Mar 22, 2008 | Dishwashers
Gltf530dso frigidaire washer
http://www.appliancepartspros.com/frigidaire-vane-131274600-ap2106479.html
This is the part. You have to remove all the panels, The drum counter weights and finally the drum. Then you have to remove the inner drum from the plastic outer drum. Once removed you can get to the screws that hold the paddles in place. Then put it all back together. It may be easier to call a repair man in your area.
May 23, 2014 | Washing Machines
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
How to remove water filter paddle for ge fridge
From the looks of the illustration you'll have to first pop the trim off from around the dispenser area using a small flat head screw driver. Once that is done remove the control panel, which is sometimes held there in place with a screw from bottom area of the board. Lift the board out of the retainer that holds it in place and you disconnect any wiring to remove it completely. Once that is out of the way you should have access to the paddle to replace it. Be sure that the machine is unplugged when you start, don't want to get shocked
http://www.partselect.com/ModelFrames.aspx?ModelID=1598847&ModelNum=PFCF1NJXABB&mfgModelNum=&ManufactureID=2&Selected=00127059i01&Position=2&mfg=GE&Type=&Mark=2
Jun 22, 2012 | General Electric PFCF1NJX Bottom Freezer...
One blade does not turn
The left blade on a BD 2300 bread maker did not turn when neading the dough. I took it apart by removing the six screws in the bottom of the case and the screws inside around the bottom outer edges of the metal insert. I then removed the screws holding the motor assembly to the base. I found that the metal plate attached to the paddle shaft driven by the gear had torn through the plastic gear, and was no longer driving the paddle. I made a new plate with the end bent down 90 degrees so that it fitted into a slot in the plastic gear. This is much stronger and the breadmaker now works fine. This is a weakness in the design and the failure could occur on either paddle. failures of the left paddle could be due to the toothed belt breaking, this drives from the right paddle gear. There is also a belt between the motor and the left paddle gear.
Dec 14, 2009 | Black & Decker B2300 Bread Machine
Water dispenser Paddle
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
The part the hinge fits into may be broken or the hinge it's self.
Aug 14, 2009 | Refrigerators
Broken water paddle
remove the bottom pan by pulling it out, then you will see three screws. remove the screws. Push the fram up which will unlatch it. The asbly will now come out. pull the water hose and the electrical connector, and you'll see the screws that hold the paddle.
Aug 12, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
181 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
