Irons Logo
Posted on Jun 19, 2017
My rowenta iron leaks water from the bottom of the handle, when setting upright. It actually loses more water when cool than when I am using it. I use it often as I am a quilter, so I do not empty the water between usings. It is a DZ2060 actisteam It says Rowenta INOX There is a number 2108 near the model number. I love the iron and have only had it a couple of years, so I hope it can be repaired. [email protected] Barb
5 Related Answers
Anonymous
  • 24 Answers
  • Posted on Feb 24, 2008
SOURCE: rowenta autosteam iron dz 1700 r
The electronic device is faulty and need to change inorder for the iron to work properly.
Regards
alan
Anonymous
  • 104 Answers
  • Posted on Mar 07, 2008
SOURCE: Taking a Rowenta DX1900 Apart
Not sure about your model, but newer irons have the screws hidden under snap-on covers. Look for a small cover that may have a slot where you can insert a small screwdriver and lightly pry. Chances are you'll leave marks. They are not made to take apart so there is also a chance you'll break the internal tabs that snap/hold it together. You may be able to super glue them back. There should be a removable coverplate at, or near each end.
Anonymous
  • Posted on Aug 01, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Anonymous
  • Posted on Sep 03, 2008
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Anonymous
  • 3 Answers
  • Posted on Dec 20, 2008
SOURCE: Mold
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
How to fix water leaking out of bottom of Rowenta steam iron
I'm on my fifth Rowenta iron. The first four eventually started to leak. I keep buying Rowenta because I get the best results except for the leaking. I've been using filtered water even though the manual sas to use tap water. I will start o use tap water. The fifth one I bought was highly rated by Consumer Reports. If this new one starts to leak, I'll bring it back and buy a different brand.
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
2answers
My iron is dripping water my model number is dz6080 focus do i need a new one? It is coming out of the bottom when it is sitting upright. my ironing board is all stained and actually my floor is rusted...
cheap irons are better as they are subject to the problems of heat steam and corrosion
cost to repair will exceed the price of a new on e and that will also if parts can be obtained
3helpful
2answers
Rowenta Iron leaking out of bottom and leaks on clothes
I have one of these and have been battling the leak problem for years. I'm a stubborn mechanical engineer and I'm bound and determined to fix this, when in fact I should just buy another, different, iron.
The problem is then 'handle'. Built into the handle is the water tank. The water tank is made from two pieces which are then glued and screwed together. Think of taking a coke bottle, cutting it in half, and then gluing it back together. Now you see where the problem comes in... the glue they use isn't up to the task, or the heat... or the pressure... is causing the tank to leak somewhere / everywhere.
I have disassembled this several times, meticulously scraped out the old silicone, and tried several different types of silicone to re-seal. So far it always fails. It's good for a while, but maybe a couple months, before it starts leaking again.
Conclusion... BAD DESIGN. Very disappointing, because in every other respect I like this iron better than any I've ever owned.
My rowenta iron shuts off in the middle of ironing & spits water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Water leaks from bottom as fast as you add it. It
Sounds like the tube ot tank is ruptured. It may be cheaper to buy a new one from wallmart or similar store.
1helpful
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
3helpful
Iron leaks water
heatman101
56helpful
8answers
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
