Question about U-Line Icemaker
CLR2060 Clear Ice Maker Won't Freeze
This started out as a water line problem. Fixed that and the unit wouldn't freeze. It would start to cool and then it warms right back up. Called ULINE and they said it's the control board. $250 later, replaced the board and the thermistors and the exact same problem. ULINE techs have no idea what the problem. They insist the sealed system has a leak, but there are no leaks. Unit is not quite four years old and very clean. No oil or signs of any kind of leaking.
  • 1 more comment
  • j2jbrown Aug 08, 2008
    Sealed unit, no way to check it. No signs of leakage, though.
    This is a stand alone ice maker, not a refrigerator. Any suggestions why we're having such problems?
  • j2jbrown Aug 10, 2008
    Sounds like no one has every worked on this machine before, because all that I'm getting are guesses. We had to replace a leaking waterline and when we plugged it back in, it wouldn't freeze. We called manufacturer and said we need to replace circuit board, which we did. Same problem. Freon is fine, wiring is fine (unit is 3 years old). If we crank the ice thickness up to the highest level, it starts to freeze and then immediately defrosts. This unit seems to short-cycle but no one (not even manufacturer) knows the issue. I am hoping someone has actually seen this machine and can spread some light on this issue. The machine is quite basic, so we are truly baffled by this problem.
  • 594 Answers
If the refrigorator is not cooling and that is what it sounds like it is not doing. than get a 3in1 from your local appliance store. and replace the relay on the comprssor.... alot of the time the reays go bad and won't allow the fridge to cool..... You can also get a factory relay that will just pop on like the old one. a 3 in 1 relay you will have to wire in......
the relay tells the compressor to cool stop ect......
i would start with this. it will be the cheapest thing to start with.... the 3 in 1 is only about 10 to 15 dollars.
Posted on Aug 10, 2008
    Genius:
  • 1,269 Answers
Go for new freon
Posted on Aug 08, 2008
    Master:
  • 521 Answers
Go through the following site which will provide u the manual n diagrammatic instructions about ur unit.may be it will help u out to reach n rectify the exact problem.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Click this link for the manual and read the instructions from page no. 30 to 37....
http://dl.owneriq.net/b/b99a53b9-52f3-4b81-8287-8f5c7badfbc5.pdf
Thanks
Good Luck
    Genius:
  • 2,035 Answers
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals...
    Guru:
  • 147 Answers
J2,
I believe the problem is electrical. Bad wiring doesn't give the unit the juice required to stay cold, and it needs quite a bit of that. I'm sorry but the whole unit has to be replaced, or completely gutted and new electrical wiring put in.
Good luck and take care,
Chimpster
  • 19,396 Answers
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. From repairclinic
    Master:
  • 623 Answers
Might be low on freon check it
  • ritchie dempacco
    ritchie dempacco Aug 10, 2008
    check your condenser....
No Water to Ice Maker. Model # GTS181CMDRWW.  Water from supply OK no water  freom lower pumpt up to ice maker unit
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Oct 11, 2009 | Refrigerators
Water line hooked up to unit for icemaker but water will not travel up plastic line to the icemaker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Sep 12, 2009 | Maytag MTB1895AE Top Freezer Refrigerator
Ice machine not working, I have water in the door but no ice. looks like there might be a ice buildup. I had a leak in the water line and this problem started after I fixed the water line
Is the ice buildup in the ice bin storage or ice maker. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 04, 2009 | Refrigerators
Amana refrigerator model th121tw ice cube maker is not freezing. It freeezes some ice cubes but accumulates water in the tray below
Aug 29, 2009 | Refrigerators
Ice maker filling with water but not freezing into cubes.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker won't send water to unit. Solenoid is good
Make sure the fill tube where the water goes into the ice mold is not full of ice. Your old valve may have been leaking and it will freeze in the fill tube. Other than than maybe start the ice maker working by filling it with water and see if it dumps and refills.
You can swap the wires on the inlet valves and try the water dispenser. The water should go to the ice maker letting you know the valve works and the line is clear.
Aug 15, 2009 | Refrigerators
Ice maker not making ice
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Dec 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice Maker
The heating coil in the unit may be activated which cause water not to freeze....
To know were the heater is located .Please check on this link:
http://home.howstuffworks.com/icemaker1.htm
Aug 10, 2008 | U-Line Icemaker
Water is not supposed to run all the time. Maybe you have a problem with your solenoid or the circuit that shuts your water. Sometimes solenoid just needs cleaning.
Aug 08, 2008 | U-Line Icemaker
U-Line Icemaker Logo
333 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
