Plantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset Logo
Posted on Apr 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't fast forward/rewind songs. I press and hold the forward button, and a voice says "fast forward" or something similar, but then nothing happens. If I then press the same button after hearing that voice, it only increases the volume. What am I supposed to do to skip or rewind a song?
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 537 Answers
  • Posted on Oct 24, 2011
Anonymous
Expert
Level 2:
Prodigy:
Answers
537
Questions
0
Helped
161529
Points
569
Below is the link for the Backbeats User's Guide. See page 12 of the guide for the controls on how to fast forward/rewind your music.
Plantronics Backbeat User's Guide
Good luck from Headsets Direct!
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
5helpful
2answers
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
84helpful
4answers
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
2answers
How to cancel on hold? model nwz-A818
Press and hold the Back/Home button for several seconds - see if the Settings Menu appears. Go to Video Settings and turn off the On-Hold Display.
How do you erase dictation from a Lanier dictaphone?
Download book
To listen to audiobook content, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Music from the Main Menu.
3. Scroll down to Audiobooks and select it.
4. Use the thumbwheel to highlight and select the desired book.
5. Press the >>| button to skip to the next chapter or press-and-hold the >>|
button to fast forward.
5. Press the |<< button to go back to the previous chapter or press-and-hold the
|<< button to rewind.
6. Use the thumbwheel to adjust the volume level.
USB folder names-Kenwood KDC-X591
Push the AME button in the upper right hand corner of the unit and at the same time hold the fast forward button on the face of the unit - do this for 5 secs. The word "Code" should pop up (not blinking).
Using your remote control press the following numbers:
5 (two times for letter "K")
2 (three times for letter "C")
2 (one time for letter "A")
7 ((two times for letter "R")
Then using your remote control, press the fast forward button and you are done. "Approved" should pop up on the unit.
Hope this helps!
1helpful
Ineed a manual for a Fisher VCR
This may help.
Hold down tv power enter the 2 digit code using number buttons 0-9 then release tv power button
Admiral 05, 10 13 - Emerson 17 - Fisher 03 – GE 07 – Gold Star 01 – Hitachi 02 – JVC 15 – Magnavox 08 – Matsushita 12, 18 - Mitsubishi 14 – Panasonic 12, 18 - Quasar 12, 18 – RCA 06 – Samsung 16 – Sanyo 03 – Sharp 00, 13 - Sony 11 – Technolace 05 – Toshiba 04 – Zenith 09,10
And now the impossible clock setting. Turn unit on press clock while holding down the shift button. Press fast forward or rewind to change hours, then press adjust while holding down shift button to select the minutes again use the fast forward or rewind arrows to change minutes then again the adjust and shift combo to start clock.
Good luck Kevin
Fishers help line is 1-800-421-5013
1helpful
Rn 305 doesn't record nor play
I had a similar problem and found out the batteries are weak and changed to a new batteries. Now it works
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
