Question about Lexmark Office Equipment & Supplies
No usb lead for x2650 - Lexmark Office Equipment & Supplies
    Master:
  • 521 Answers
You can get it in any electronics shop who keeps computer peripherals.
Posted on Aug 08, 2008
Is there a wireless print server available for this printer?
You can make any printer with a usb port wireless by adding a usb to wireless print server. Linksys makes them. Keep in mind that typically over this type of connection you will not be able to utilize scanning functions if it has them.
Aug 23, 2015 | Lexmark X2650 All-In-One InkJet Printer
Is this printer wireless? or do I have to use the usb cabl to print?
it seems that wireless is not supported, and you must use a USB cable. Check that the connectors are the correct ones; printer accepts a type B ('house') male connector (plug)
If uncertain consult Lexmark support, or the manual for this printer. Information (including probably a manual) can quickly be obtained from the webpage
All Products Printers MultiFunction Lexmark X2650 Lexmark
The image shows two connectors (which may be on either end of a single cable, and what I think you need) lower is type B (printer end) , upper is type A (computer end, most commonly). Available in various lengths, you need USB 2.0 spec.
Apr 10, 2015 | Lexmark X2650 All-In-One InkJet Printer
Wont print
Please check your usb cable connection to the pc, beta still you may swap usb ports. It should print after you restart your pc. If not open "printers and faxes" window from your control panel and select the LEXMARK as a DEFAULT printer. Thank you.
Jun 06, 2011 | Lexmark X2650 All-In-One InkJet Printer
What kind of cor shall i have to connect lexmark x2650 to hp compaq cq61 notebook
The Lexmark X2650 appears to have one or more USB port. At http://www1.lexmark.com/US/en/catalog/product.jsp?prodId=4280 click "View more specs" Near the bottom, you will see:
  • Standard Ports
  • USB Compatible with USB 2.0 Specification (Type B)
The compaq cq61, being a modern laptop (runs Windows 7), would undoubtedly come with one or more USB ports. The cable you would want is a USB cable with an "A" connector on one end and a "B" connector on the other end. (sometimes referred to as a USB A/B or A to B cable). 6 ft is standard length for a printer cable, but if you are placing the printer further away than typical, you will need to purchase a longer cable. If you google "USB printer cable", this is the type of cable you will find. I see some for 1 or 2 dollars, but I know you can get better quality ones for more. The 1-2 dollar ones would probably work just fine, though.
Apr 18, 2011 | Office Equipment & Supplies
Lexmark X2650 3-In-One Printer/Scanner - no power! - It has lost power totally. I wasn't using it for a while, so i had disconnected it and packed it back in it's original box for a few months....
your problem may be ur power adapter has gone out... try replace by checking your input volts and ampere as well as output volts and ampere. you can use compatible also. if same problem occurs it might be the power supply area problem inside the printer
Mar 15, 2017 | Lexmark X2650 All-In-One InkJet Printer
I do not have any instructions and want to photo copy.
Go to link below, you should be able to download your printer manual from it. Lexmark X2650 All-In-One Inkjet Printer User Manual Free Download User Manual: Lexmark X2650 All-In-One Inkjet Printer - Service Manuals, User Guide, Reviews, Instruction Manuals and Owner's Manual.
www.generalmanual.com/Printers/Lexmark-X2650-All-In-One-Inkjet-Printer.htm ·
Nov 04, 2010 | Lexmark X2650 All-In-One InkJet Printer
Does my x2650 printer need ink to scan?? Just
does not need ink to scan. however some printers might give you an error or won't let you do anything if it does not detect a ink cartridge.
Oct 17, 2009 | Lexmark X2650 All-In-One InkJet Printer
Error on newly installed printer.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Lexmark X2650 All-In-One InkJet Printer
Need help using x2650 scanner
Lexmark X2650 printer instructions for using scanner
Nov 07, 2008 | Office Equipment & Supplies
Can not install lexmark x2650 do i need a usb lead
yes it is nessary to load your printer you can get it in any electronics shop who keeps computer peripherals.
Aug 08, 2008 | Lexmark Office Equipment & Supplies
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
