Question about Science & Laboratory
BSA 3-12 x 50 Rifle Scope
I bought this rifle and it came with BSA scope. Its worked fine for the last two seasons, but while cleaning the gun for storage at the end of the season, I noticed that the crosshairs turn when i adjust the power level. Is it worth it to get it fixed or better to just buy a new scope?
    New Friend:
  • 56 Answers
But a new scope. Having the crosshair reseated will cost you more than getting a new BSA scope.
Posted on Apr 03, 2018
SOURCE:
SOURCE: BSA rifle scope
its a metric 1.5 for the cam adjustments
Posted on Jan 15, 2008
SOURCE: Scope will not work
Changed both lamp bulbs.
Posted on Dec 01, 2008
Adrian762
  • 425 Answers
SOURCE: 3-9x50 BSA Deerhunter Rifle Scope.
What that means is they are not mounted correctly. The scope mounts should be square with your rifle when fitted, when the scope is placed into the mounts, it should be turned to be square with the rifle.
Firstly, make sure you do not "cant" when you shoot. That is hold the rifle at an angle instead of vertical. Once you are sure that is OK, then put it into a vice using blanket or some other soft material to protect the stock. Get the rifle perfectly square using a spirit level. There should be a flat spot on the top of the action that you can use. Once this is achieved, you loosen off the scope mounts and square the scope up to your satisfaction. Once done, tighten the mounts up and then remove from the vice.
Posted on Feb 10, 2010
  • 43 Answers
SOURCE: Just acquired a used "Micromaster" scope from
If it repeatably blows the fuse, it is a transformer problem. You can order a new one through Fisher Scientific. The part # is XP-MC2-TR1. They are around $40.
Posted on Dec 30, 2010
SOURCE: The elevation adjustment on my BSA air rifle scope
how to fix crosman rifle scope?
Posted on Jan 16, 2011
I have a BSA point 22 carbine air weapon circa 1990. Could you tell me what the name of the carbine is?
Hello Jean
It is likely to be a BSA Meteor or a BSA Airsporter. I am from Birmingham UK and owned one.
Here are a number of links for you which will help identification. I will put the Google link at the very bottom of the post which lists a lot more info. Write back as a COMMENT below my post if you need any further help. I am one of the air weapon experts.
  • 1990's Air Shot Corp./BSA Catalog, Vintage Gun Catalogs www.vintageguncatalogs.com/product_info.php?products_id=57 Circa 1990 Air Shot Corp./BSA Catalog,8-1/2" x 11" with 6 pages Content: ... Air Gun Catalogs. Air Arms; Beeman; Benjamin; Brno; BSA; Crosman; Daisy; Feinwerkbau ...
  • History & Ethos ' BSA Guns - BSA Air Rifles bsaguns.co.uk/about/history.aspx BSA Guns; History & Ethos; Production ... 1962 Introduction of Merlin air rifle; 1962 Introduction of Armatic .22 self ... and Airsporter Carbine air rifles; 1990 ...
  • BSA - John Knibbs International Ltd - Airgun Spares www.airgunspares.com/store/content/87/BSA Superstar .22 : 1990 - 2004: R22: R - 10 MK1 .22 : R77: R - 10 MK1 .177 : ... BSA Standard No2 Air Rifle .22: 1936 - 1939 : T: Ralock Self Loading Sporting Rifle .22 ...
  • BSA .22 Air Rifles and Pellets ' Wonderland Models https://www.wonderlandmodels.com/bb-air-guns/air-guns/rifles/bsa BSA .22 Air Rifles and Pellets. Wonderland Models are an Online Model Shop specialising in BSA .22 Air Rifles and Pellets and ... BSA Rifles Meteor Evo Air Rifle.
  • JC Militaria ' Air Weapons www.jcmilitaria.com/air_weapons.asp?Start=10 At JC Militaria we stock a number of Air Weapons. ... 22 Calibre Bolt Action Single Shot Air Rifle ... BSA launched a centenary air rifle to ...
  • BSA Air Rifle Combinations - The Airgun Centre https://www.theairguncentre.com/rifle-combinations/bsa BSA Guns are at the cutting edge of Air Rifle design and manufacturing and have a history going back over 150 years.
  • Blue Book of Airgun Values - BSA GUNS (U.K.), LTD. RIFLES ... bluebookofgunvalues.com/Airgun_Values/Airgun_Manufacturer_Models... ... LTD. RIFLES: MODIFIED REAR/UNDER LEVER COCKING airgun ... RIFLES: MODIFIED REAR/UNDER LEVER COCKING . ... faucet tap loading, Marked: "THE BSA AIR RIFLE ...
  • http://www.bing.com/search?q=BSA+22+air+rifle+circa+1990&FORM=HDRSC1
    Jul 05, 2016 | BSA Optics
    Mounting
    Any scope will mount on any rifle using the appropriate mount and ring combination. It shouldn't be a problem to mount it on your savage.
    Mar 27, 2014 | BSA Sweet .17 Rifle Scope
    I recently recieved a BSA Radiant 3x9x40IR rifle scope with no manual. How do you turn the power on/off or do you have to remove the battery?
    Most, by far, the majority of these types of scopes with electronice dots, or other enhancements requiring a battery are turned off when you return the power setting to zero ( 0 )
    This is regardless of the manufacturer.
    And almost all of the time the power control is integrated in to either the top or side turret, or adjustment knob.
    Also most of the time the battery is a # 2032 which is flat and about the shape of a quarter / $.25.00. They last indefinitley until you forget to turn off the power!
    hope this helps!
    Mar 10, 2011 | BSA Air Rifle 3-90X40 Ir Red Dot Scope
    Cross hair broken on my B S A mil dot 4-16 x 40 scope will any gun shop be able to repair
    Yes, more than likely.
    The scope just needs to be disassembled and the crosshair flange repaired or replaced.
    A dealer should be able to order the part or at least fit one similar enough to work.
    The trick is not to allow any moisture into the scope's internal cavity during the repair.
    Mar 06, 2011 | BSA 4-16X40mm Mil-Dot Rifle Scope - ...
    What does the 6-24x40 mean in rifle scope?
    Good day,
    The 6-24x is the magnification that the scope provides and the 40 stand for the lens diameter in millimeters.
    Hope this helps!
    Regards
    Feb 10, 2011 | BSA ® 6 - 24x40 mm Rifle Scope Matte Black
    I have age 3by9by40ir scope. it has a illuminator red dot in crosshairs .problem is need to use much strength to turn on.any way to fix? scope is brand new. somewhere to send?was achristmas present. use...
    I've never had that problem with my scopes, but BSA's customer service department welcomes questions and comments. I bet they'll have some good advice. Here's their contact information:
    954-581-2144 (Monday - Friday 8.30am - 5.30pm EST)
    BSA Optics, Inc.
    3911 SW 47th Ave. Suite 914
    Ft. Lauderdale, FL 3331
    Jan 22, 2011 | BSA ® Huntsman Series?? 3 - 12x50 Rifle...
    I just bought this bsa deerhunter with the rear adjustment. I have never sighted in one before. What is the best way to sight in this type of scope and what is the rear adjustment for?
    start off shooting at a range of 20yds no more off a bench rest
    when you have a zero move back to 50yds you will find it will shoot bepending on the gun highter or lower but in line its just a mater of putting the cross on the target shooting a round and without moving the gun at all, move the cross over the hit from the bullet strike,,,thats it then its zerod
    Aug 07, 2010 | BSA ® Catseye Series?? 3 - 10 x 44 IR...
    Feb 10, 2010 | Optics
    BSA rifle scope
    Nov 11, 2007 | BSA Big Cat 3.5-10X 42mm (3.5-10x42 mm)
    Science & Laboratory Logo
    547 people viewed this question
    Top Science & Laboratory Experts
    Pokinhas
    Tom Chichester
    Are you a Science and Laboratory Expert? Answer questions, earn points and help others
