Question about Panasonic DMR-E55 DVD Recorder
Error message when we try to play a dvd we get error message rf ch21 come up and it will keep resetting itself, please help!
  • 185 Answers
Hi
This is not an error code!
RF CH21 simply refers to a channel that the recorder is set to and is the first channel it will display. For example, there is no CH20. Your recorder is trying to find stations on all its channels from CH21 through to around CH70 and when it gets to the end if it doesn't find any stations, it starts the process again. This will often happen when you first unpack the unit from new until it has been set up.
Firstly, make sure you have a TV antenna connected, even if you use a satelite receiver. If no antenna is connected, your poor old set will keep on searching until you tell it to stop. Incidentally, connecting an antenna will allow the machine to set the clock automatically too. Next, go into the menu options, this is incredibly easy, just follow the on screen prompt.
Find "Tuning Set Up" and make sure that it is not set to auto. If the recorder still continues to show CH21, you will need to switch the unit off from the power socket and leave it for at least 15 minutes before switching back on. Then repeat the above.
I am almost certain you'll fix this, because it sounds as though the machine is doing what it is supposed to. If it still doesn't work please give me a few more details.
Best wishes.....
Posted on Aug 26, 2008
SOURCE:
No disc error dvd on Harman BDS
maybe try cleaning the laser ? with a cotton wool bud and metho
Jul 28, 2013 | Harman Kardon Audio Players & Recorders
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
Lost power while recording a dvd when power came back, i keep getting the "incorrectdisc" error message. I've done the up-channel/play reset/initialization trick several times, but keep getting the...
the "expert's" advice was about as useless as could possibly be- I had already tried all of his suggestions several times before even contacting fixya. what a freaking WASTE of $20.
The only thing left to try is unplug that piece of **** for, oh, say, a month, to let the capacitors discharge completely and hope that the error message goes away. If that doesn't work, the unit is going into the sh*t can.
Oct 05, 2009 | Toshiba DR4 DVD Recorder
Panasonic DVD/VCR player: ''Error'' message
Try a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 03, 2017 | Panasonic Televison & Video
Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Avh-p5900dvd when trying to play dvd or cd comes up with...error-02-9e can you please help.
Here is the Pioneer error code table:
First Second Error
Digit Digit Description
0 No major error
1 Antenna not connected
2 Shorted antenna cable
3 RF circuit failure - PLL not synchronized
4 Undefined/Reserved
5 NVM Error
6 Defective CAP or not connected
7 Unknown DSP SW version
0 No minor error
1 CDEC Communication Error
2 SSDEC Communication Error
3 SSDEC No Response (DSP core freeze)
4 No signal/100% BER
5 Not activated
6 Not authorized
Your error indicates an
SSDEC Communication Error.
You should try resetting the unit to clear this error.
Apr 02, 2008 | Televison & Video
Error 2
my vhs/dvd combo sylvania shows error 2 how do i fix this
Nov 15, 2007 | Sylvania SRD3900 DVD Player/VCR
DVD playback problems
Did you buy these DVD's out of the country? Are they burned? did you pick English and the United States of America when you set up the dvd player? Try unplugging the player for an hour, plugging in and resetting everything up
Jun 03, 2007 | Zenith DVT216 System
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Panasonic DMR-E55 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
