Question about LG Refrigerators
I need to know how to remove the ice tray from an LG refrigerator model # LRSC26925TT
  • 210 Answers
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
Posted on Jun 03, 2008
  • 330 Answers
SOURCE: Have a 2005 model#LRSC26925TT LG
When you order the new replacement, did you ask the supplyer whether it can be replace the old panel? Sometime the wireing inside is different, I do not suggest you touch it unless you got the panel is completely same size and same founction and you know how? Otherwise it is a headache.
The panel must be right one.
Posted on Jul 21, 2008
stradeteox
  • 88 Answers
SOURCE: LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Posted on Jan 12, 2009
BIKER T
  • 909 Answers
SOURCE: Ice maker wont shut off
So many different types. lots of info needed. In short, lg have DIPswitches on main board. By adjustment of these switches, the water in can be controlled.I dont think there is a water sensor on these makers per say.Does the water ever switch off at any time and if so, is the inflow time constant?. Assuming the solonoid valve is not defective.
Posted on Jan 30, 2009
SOURCE: Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Posted on Apr 09, 2009
How do I remove the ice tray from LG Refridge Model # 25976
You have awater problem not an icemaker problem...inlet valve bad or water source problem....
Oct 02, 2012 | LG LFX25976 (247 cu ft) Bottom Freezer...
We have a LG Fridge/freezer model number GRL247WV and the ice tray in the ice maker is broken. The part needed is apparently discontinued and unavaliable. Do you know of an alternative ice tray that could...
Hi!!
If you take your old ice tray to any Appliance Parts Store (check your phone book for the one's near you). They should be able to sell you one that will work for you.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 08, 2010 | LG Refrigerators
Icemaker overflows water into the ice bin
The ice maker should be replaced.
You can order it on line and replace it yourself.
1 screw and a wire harness connector.
LG part# 5989JA1005F about $104.00
Factory service is availiable in Dallas.
Call LG back if you need a technician if they are not helpful please let me know.
I work for the factory!
Jan 16, 2010 | LG LSC26905TT Side by Side Refrigerator
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Jul 08, 2009 | LG Refrigerators
Jan 17, 2009 | LG LSC26905TT Side by Side Refrigerator
L.g. lrsc26925tt refrigirator - side by side - ice maker
Greg...I got this fridge and had the same exact problem and more...long story short..I totally gave up on the ice maker in this unit.Very bad design. you will go crazy trying to keep that ****** going...trust me.
Nov 23, 2008 | LG LRSC26925 Side by Side Refrigerator
Ice maker LG side by side
What is the model #? Get it off the sticker inside the refrigerator side.
Oct 08, 2007 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
