Question about HP DeskJet 825c InkJet Printer
Does not print black
I installed a tri color HP17 and set up for that configuration
Will not print black, all black prints as gark green.
Help
  • 1,049 Answers
Either the print nozzle is clogged or you have a bad cartridge. Use windex or alcohol on a cotton swab and scrub lightly in a circular motion where the ink cartridge touches the print head under it. Then replace the black ink.
Posted on Aug 08, 2008
  • NA NA
    NA NA Aug 08, 2008
    That's true, but I would hope you would know if your cartridge wasn't installed. :o
    Scholar:
  • 144 Answers
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
SOURCE:
Photoshop prints only black and white
I don't know what you mean by 'set for color output', but be careful there is a way to set the printer's 'preferences' through the PS PRINT DIALOG BOX... those settings can be different than your regular printer settings. Look for it when accepting the send to printer parameters.
Dec 07, 2014 | Adobe Computers & Internet
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
Aug 10, 2011 | HP Color LaserJet 2600n Printer
Hi. I need to make default setting to print grayscale. Kindly give me the steps. Thanks
Color/black mix
This item allows you to configure printer settings to optimize printer and cartridge performance for the printing environment. If the printer is primarily used for black printing (over two-thirds of the pages are black only), change the printer settings to MOSTLY BLACK PAGES.
Setting the color/black mix
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight SYSTEM SETUP.
5. Press to select SYSTEM SETUP.
6. Press to highlight COLOR/BLACK MIX.
7. Press to select COLOR/BLACK MIX.
8. Press or to select the desired option. (Select MOSTLY BLACK PAGES)
9. Press to select the option.
10. Press Menu.
Select MOSTLY BLACK PAGES if you print mostly monochrome print jobs, or a combination of color and monochrome print jobs.
Product User Manual (You may like to refer to Page 65)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 4700 Printer
Printing is in green
Check the print settings. I guess you are printing black texts in black color without proper settings.
Open the Printers and Faxes from the Control panel, (or from the Start Menu), right-click the printer's icon, select "Printing Preference" and from the printing preference window, click "Features" as shown below,
Click "print in grayscale" then select, "Black ink Only", click "Apply" then "Ok", now try print again. You'll need to restart the program (if you are printing from a program like Ms-word, etc..). This should fix the issue.
This happens when the color is set to high quality, means it uses only the color cartridge instead of the black cartridge.
If you need further help, let me know.
Good luck
Thanks for using FixYa.
Sep 06, 2010 | HP Office Equipment & Supplies
Only prints in black. Windows 7 driver update
Print a 'Configuration Page' from the printers <Information Menu>
Press the green tick button to enter the menus, and use the <, > arrows to scroll thru menus.
Then press the green tick button to select...
If, as I suspect, your Configuration Page is in colour, and looking ok - the the problem is in your computer - Printer Driver setup, or Windows......
Like all the others
Have fun.
Dec 21, 2009 | HP LaserJet 2605DTN Color Printer
I cant print in color
If your trying to only print form a tri-color in cartage and you dont have a black cartage in the 2nd slot as well you might try doing the following
I am not sure whether u can print only using one cartridge(color) with this All-in-One. Check out the following steps nd let me know if they have helped.
1. Remove the Black cartridge from the All-in-One.
2. Open HP Director.
3. Click Settings -->> Print Settings --->> Printer Toolbox.
4. Under the Configuration tab, select One Color cartridge from the drop down list and click apply.
Now,try printing.
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Compaq IJ650 ink jet printer will not print color.
Just because it’s new does not mean New Old Stock. Your print head is plugged. No if or buts about it. Contact HP and tell them you situation. If they don’t help you, box it up and take it back. Buy an Epson.
Jan 08, 2009 | Compaq Inkjet IJ650 Printer
HP LaserJet 1500L
Hi Larry , Here are a couple of soultions that may correct the problem.
1.Color mode is not selected in your program or printer driver.Select color mode instead of grayscale.
2.The correct printer driver is not slected in the program . slect right printer driver.
3.The printer is not properly configured.Check the configuration page by printing a configuration page.If no color appears on the config page replace the drum unit.
Dec 03, 2007 | Office Equipment & Supplies
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
HP DeskJet 825c InkJet Printer Logo
304 people viewed this question
Clive
Clive
Thomas F. Schneider
