Brynn_parson:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
SOURCE: Whirlpool dishwasher adg7540
where do you live that model doesnt come up in my data base the first thing your washer should do when you turn it on is drain then fill then go to wash try this it should put it in self diag if this dont work reply we will try another
HIGH TEMP SCRUB, AIR DRY, HIGH TEMP SCRUB, AIR DRY push thoose see if it goes into self diag
SOURCE: problem with whirlpool dishwasher ADG957
Continuous flash with no pause is a Faulty NTC (temperature sensor)
Or according to whirlpool it might be that your keys are syticking.
SOURCE: Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
