Question about HP Office Equipment & Supplies
Hello there, I places a new (remanufactured) colour cartridge in my printer and check print cartridge light flashes.
    Master:
  • 521 Answers
Check whether the cartridge is of same number,it is installed properly, the tape on the nozzle of your cartridge is properly removed, try cleaning the brown dotted circuit of both the printer and cartridgethrough moist tissue.install the old cartridge and see whether it is showing the same error or it could be the problem with your black cartridge or get your both the cartridge checked in another printer of same model number if you can.
Posted on Aug 08, 2008
  • 446 Answers
The cartridge could be bad, usually ther is a small chip that goes with cartridges, you forgot to mention the model and brand.
try re installing once again if not pls replace the cartridge one more time
All the lights keep flashing --won't print!
I removed the black ink cartridge that was REFILLED at a popular retail outfit and replaced it with a remanufactured one I bought on the web. As soon as I closed the lid, the flashing stopped and it has been working GREAT ever since. Many postings had already recommended the changing to a "new cartridge" to remedy this flashing lights and "pen failure."
Jan 14, 2010 | HP Photosmart 2410 All-In-One InkJet...
Canon PIxma ip2600 not printing
Hi
Maybe that the chip itself is faulty. I would take back and ask for a replacement.
Taz
Nov 09, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Have just installed new ink cartridge and colours will not print properly New colour cartridge from cartridge world not had this prob b4
If it's not an original cartridge you can expect problems. I tried remanufactured or OEM type cartridges and lost an Epson and a HP printer to printing problems within a week.
Have you tried carrying out the printhead cleaning and alignment procedures since fitting it ?
Nov 04, 2009 | HP Officejet 6310 All-In-One InkJet...
New black ink but very poor quality print?
Is this an original DEll toner, or a remanufactured one?
Sometimes a remanufactured cartridge can need a few pages printed before the new toner 'works ' through the internal mechanisms. Not all remaufacturers actually test (all) of their cartridges. The better ones test 100%, to ensure a quality product.
It could be that the wrong toner has been used in the cartridge (not all toner is the same - by a long way).
It could be that the drum has NOT been replaced. These can be light damaged and result in a poor print quality. An original drum is purple in colour. Aftermarket drums are blue/green.
Nov 02, 2009 | Dell 3110cn Laser Printer
Hp 5550 print cartridge light flashing.power light on,not flashin
All HP ink cartridges are dated. If you are using the remanufactured ones the date is not changed and will not work properly at all. By HP ink only and you will never run into this again.
Sep 03, 2009 | HP DeskJet 5550 InkJet Printer
Right cartridge incorrect and printer will not
I have the same issue where the printer displays "Right cartridge Incorrect". However, it's had no problems up until about two weeks ago and I've had the right cartridge in place for about a year or so.
Printer: AIO 922 (All-In-One 922)
Ink: Remanufactured ink
Jul 11, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
Jan 19, 2009 | Lexmark E250dn Laser Printer
The new light cyan cartridge was not printing...I thought it may be faulty so purchased another which also did not work. I did 'clean print head ' several times followed by nozzle check. All other colours...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Ink light keeps flashing -
Have you made sure that you've taken the plastic strip off of the ink cartridge? I had this problem once and I then realised that i had forgotten to remove the strip covering the ink.
Also, have you installed a colour cartridge? I have the same printer and it wont print unless you have both ink cartridges inserted and in good condition. (If you don't want to fork out for HP Original, I find that the Tesco Remanufactured versions work fine)
Hope this helps.
Joe
Jan 01, 2009 | HP DeskJet 930c InkJet Printer
Ink Cartridge
Lexmark/Dell info
Before you buy a remanufactured Lexmark or Dell inkjet cartridge please carefully read and understand the following:
The more recent ranges of remanufactured colour Lexmark and Dell ink cartridges have been remarkably unreliable - the failure rate being massively higher than all other remanufactured goods we supply. Our remanufactured HP's, Canon, and older Lexmark/Dell ranges remain very reliable.
At seems almost certain the micro-electronics in these cartridges have been developed in the factory to ensure failure at a given point. THE MODELS MOST LIKELY TO CAUSE PROBLEMS ARE THE LEXMARK No1, No2, No3, No29, No33, No35 and No43, AND THE DELL MODELS TO FIT PRINTERS 922/924/942/944/962/964 and Dell printers sold in the last 12 months. For some reason the problems seem to be with colour cartridges - black units remain reliable.
On the reverse of a brand new Lexmark 29 colour cartridge box (in print so small it's almost impossible to read) it says: "THE PATENTED PRINT CARTRIDGE CONTAINED INSIDE IS LICENSED FOR A SINGLE USE ONLY AND IS DESIGNED TO STOP WORKING AFTER DELIVERING A CERTAIN AMOUNT OF INK. A VARIABLE AMOUNT OF INK WILL REMAIN IN THE CARTRIDGE WHEN REPLACEMENT IS REQUIRED." In plain English this means the cartridge will certainly fail - even when there is ink inside.
Although this is not printed on the boxes of certain other models, the high failure rate suggests similar technology is deployed. A perfectly good remanufactured cartridge can be installed, and used - albeit temporarily. Suddenly and without explanation, an error message "UNSUPPORTED CARTRIDGE" appears, and the cartridge refuses to work ever again. Most will almost certainly end up in landfill.
Jan 23, 2007 | Dell 924 All-in-One InkJet Printer
Seeker5211
Seeker5211
