Question about Nokia 3230 Cellular Phone
My phone is continously getting restart and lower battery
Since 6 days my phone getting restart and lowered down my phone battery I have also changed battery still problem continued and all my data and contacts have automattcaly deleted.
    Genius:
  • 2,035 Answers
This could problem with corrupted software or your phone is been attacked by a virus you need to reinstall the phone software , please give it to a local service center and get it done.....
Good luck..
Posted on Aug 08, 2008
SOURCE:
Iphone 6 camera not responding to touch
Hi Sheila
If you have tried the Full Reset
Hold Home and top Side button down for 15 seconds
Shuts down
Top side button to restart
if that Fails you need to drop int an Apple Shop - book first
or mail it in
Good luck
iPhone 6 How to Hard Reset Reboot No iTunes Lost Password or Disabled
Many More tutorials
iphone 6 reset without password YouTube
Mar 14, 2016 | Apple iPhone Smartphone
Losing battery power faster
Batteries on cell phones will demonstrate a quicker discharge for the following reasons:
1. You are in a coverage area that is weak. This is because your antenna is using more power to pick up an acceptable signal.
2. If your cell phone has a browser or other applications that can run simultaneously or in the background, you might "think" you've exited an application when in fact it's just minimized or hidden. Either try to find the application that's running in the background or restart your phone (pull battery) to clear memory.
Tips: Adjust the screen brightness lower, reduce vibration rings, set timeout or inactivity time lower.
Hope some of this helps...
May 20, 2010 | Samsung Star GT-S5233 Cell Phone
The battery will charge to 99% then will not recognize the charger at all until I turn the computer off and restart it.
you should let the computer run down its power until it turns off and then it has re calibrated the battery so it will charge fully. if you don't calibrate your battery every once in a while the amount it can charge gets lower and lower.
Feb 21, 2010 | Toshiba Satellite A135-S4527 Notebook
The time is off one hour how do I fix it...Nortel
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modular 0x32 control unit which will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, press back (lower left arrow)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then Chng Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Oct 28, 2009 | Nortel T7316E 2-Line Corded Phone
How can i change the time on my meridian M7324 phone NT8B42???
Oct 27, 2009 | NorStar M7324 Telephone
Setting the correct time
Oct 27, 2009 | NorStar Meridian M7310 Phone
How do i set the time?
  • Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
    When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
    Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
on older systems like the 616 or 8x24, when you enter in the login and password the screen will display "A configuration", press next til you see "B general admin" press the show key the display should say "1 speed dial", press the next key til you see "3 time and date"press your show key and follow the earlier directions
Oct 12, 2009 | NorStar T7316E Corded Phone
How to set time and date flash 2
the time and date are maintained on the phone system. Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If that doesn't work you may have the newer Compact ICS or the Modular 0x32 control unit wish will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Mar 21, 2009 | NorStar Startalk Flash 2 Phone
Change the time on the phone Have not been able to change it since the time change 2 weeks ago
If that doesn't work you may have the newer Compact ICS or the Modulur 0x32 control unit wish will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
Mar 20, 2009 | NorStar M7310 Corded Phone
Random restarts, possible battery problem
stdnm11-
You should see about getting a new back cover. Try ebay, they run only a few dollars.
It sounds like you battery is coming loose a bit. Without the back cover snapped in tightly, there is a bit of room for movement for the battery. so when you snap it closed, the battery pops up of the contacts. If you know any one else that has a razor, try their cover to make sure.
Feb 05, 2009 | Motorola Mobility RAZR V3
Nokia 3230 Cellular Phone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
