I don't know alot about computers and printers i bough a printer/copier/fax machine and i already set it up but i dont understand how to put it to the computer so i can print papers from the computer
  • Justin Case
    Justin Case May 11, 2010
    Hi there stmddr1228,
    Let's see if we can get you fixed up. I'll explain what what you need to do and why. You are my eyes and hands. When we are done, not only will your printer be working, you'll have a better understanding of your new acquisition.
    First off, not all computers and printers are the same. They are able to connect several ways. There are also specific drivers (how the computer talks to the printer) needed for specific printers. This makes remote tech support a bit challenging.
    So step one is: more info.
    Printer:
    • Make/Model
    • Did you buy it new? Do you have the driver CD?
    • Do you have the proper data cable?
    • Is the cable USB or Parallel? (Parallel has a 25 pin connector on one side,
    Computer:
    • What Operating System installed?
    This should get us going.
    Mike
    Scholar:
  • 144 Answers
Check which cables are provided with your printer. You need a powercable and a USB cable. Many printer manufacturers do not supply the USB cable, but this is the cable required to connect it to your PC. You can buy USB cables at almost any computer store.Just ask for a USB cable to connect a printer to the PC.
Posted on Aug 08, 2008
    Genius:
  • 1,011 Answers
Dear,
the simplest way is this,
check the model and brand of this machine and download its user detailed manual from its site or any searching websites.
regards,
dont forget to rate it
SOURCE:
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
How to get my s405 to receive a fax
You might want to check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > Pro200 Series > User's Guide. Go to page 62 to know how to setup your printer to fax.
If your fax is already setup - meaning you're already able to send faxes but not able to receive. Make sure that the Auto Answer is on. To check that, on the control panel of your printer, press on Setup > Fax Setup > Auto Answer.
If you have an answering machine, make sure that your fax will pick up 3 rings higher that your answering machine. If you answering machine picks up on the 5th ring, set your fax to pick up on the 8th ring. You can change that under fax setup.
If you have a voice mail service enabled in your phone, you'll need a distinctive ring feature for your fax to work if it's being shared on the same line.
May 23, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I can't recieve fax
The MP500 is not a fax machine. If you want to send and receive faxes using the printer, you need to have a dial-up modem in your computer with a telephone line connected. The computer then needs some kind of fax application like Microsoft Fax, which does the actual sending and receiving. The printer is just used as a scanner when you send, and to print received faxes.
If you have all this connected already and you can't receive, check your incoming telephone line and fax software settings to be sure the line is answering correctly.
Mar 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
My canon mx310 is not accepting faxes
What do you mean by its not accepting faxes? Have you correctly set up the printer and do you have your phone line plugged into it? Some printer dont actually act as a fax machine, they tend to provide you with FAX software for your computer which automatically used the printer to simply print the document out when the software has received the fax, i would check first
Mar 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Distinct ring feature
I see youve seen the solution already. Glad to know it was fixed.
Aug 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
No paper fed
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
Jul 23, 2008 | Lexmark E234 Laser Printer
Fax machine
what do you mean? you cant send? or you cant receive fax?
first know if you are using a digital or analog line. if youre using digital line you need to have a micro filter and it must be connected to the fax line. if you have an answering machine it must be connected at the back of the printer(EXT-2) to make it work. then on your printer press menu and then choose fax settings
answering mode must be YES(if you have an answering machine)
rings to answer is 1 ring less than your answering machine
disable call waiting must be set to NO.
let me know what happen
May 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
Jan 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Computers & Internet Logo
49 people viewed this question
Ekse
Alun Cox
