Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF320
What is the interlock and how can I change it?
Thanks
Gilly
  • Mr Robert Jones Sep 28, 2011
    door lock light keeps flashing and i cannot start the machine even though door is closed
    President:
  • 1,462 Answers
Interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Posted on Aug 23, 2008
    i need to at least check it as the light is flashing and i cannot start the machine even though the door sounds like it is closed.
    can i bridge it out just to see if it is this switch.
I need to get to filter on my wf320 hotpoint washing machine
Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side and find the access at the right hand side. Keep a large flat container ready to collect water from drain filter.
Pl say so if helped
Mar 16, 2013 | Hotpoint Washing Machines
How do I take the top housing off my hotpoint aquarius wf320
if you are talking about the top panel there are three screws in the back at the top of that panel remove and slide the panel backwards and it should raise right up.
Dec 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WM62P will not operate.
yes.......could be the interlock.....
cheap part to try first..
cheers
Aug 03, 2017 | Electrolux Washing Machines
Hotpoint WF320 wont spin or empty
sounds like something is jamming the pump, strip pump down and clean
May 26, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
May 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF220 won't power on
Could be the plug itself, or door interlock switch, try cutting off plug replacing Interlock cost is around 20GBP.
Oct 21, 2017 | Hotpoint Aquarius WF220 Front Load Washer
HOTPIONT AQUARIUS WF320
interlock may be stuck try changing that
May 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
221 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
