Question about Philips 60P8341 60" Rear Projection Television
Phillips 60" projection TV Double vision
We just got this TV about 2 almost three years ago and yesterday it was fine today I went to turn it on and the picture has double vision and red and blue is the color of the double vision items.Also the bottom of the screen is in a wave pattern with the same double vision and colors. Any Idea what may have cause this problem? And if so How much would it cost to be fixed?
  • 1 more comment
  • old69mus Sep 21, 2008
    As stated, I have also got double vision now, and I had absolutely now problem prior. I can solder, and on a previous solution, I noticed where someone had given the part # for the ICs and resistor...I would welcome the opportunity to repair this myself, since this is huge and awkward to transport. Thank you, Dwayne
  • Anonymous Sep 22, 2008
    same ting for me too
  • markafrancis Sep 29, 2008
    what is the solution to this
  • 4,234 Answers
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Posted on Aug 08, 2008
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Phillips 51pp9303h/17 red and green double vision of writen words and bowed line of red green at bottom. some objects in show look real shiney. and double vision of others.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
You can see some more examples and find a fix using this link on Fixya
Jan 29, 2011 | Philips 9P6031C 60" Rear Projection...
BLue will not allign
This is probably a failure in the convergace board
This should be looked at by a competant service engineer due to the high voltage in this circuit
Jun 28, 2010 | Philips 60PP9352 60" Rear Projection...
60" Rear Projection TV
sounds like a convergence chip problem...
here is my general post for the 51 inch you'll have to look at the link for the manual and check to see if you have the STK392-120 chips or somthing bigger in the 60"
you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
Where I got my parts that worked:
Suburban Electronics
Manual Library you should find all you need here:
What you need:
(2) STK392-120 OR STK392-150 IC
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Aug 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
Aug 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Phillips 60 in. rear projection approx. 10 years old
This is a common problem with the older models. The opt chip fails. You can get a repair kit at After a few months of getting smaller and smaller the audio and video will go out but the power light will remain lit.
Aug 18, 2008 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
277 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
