The computer screen (picture) rotated on me. I tried control alt. any arrow key as instructed but, problem hasn't been solved. Is there any thing else I can do to fix?
    Genius:
  • 1,011 Answers
Dear,
it seems the monitor problem.
check deguassing and other options of your monitor..
regards,
Posted on Aug 08, 2008
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
Change screen orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Dec 14, 2012 | Dell Computers & Internet
Dropped Laptop and Screen is now Sideways
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Sep 08, 2012 | HP Computers & Internet
Rotate screen back to horizotal
or
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
My screen was reverse how to adjust correct place
or
hope this helps
May 31, 2012 | Computers & Internet
Screen Rotation problem
To revert the screen to normal upright position, press these three keys together:
ALT CTRL and UP Arrow key.
(See attached image)
Hope this solves your problem. Thanks for using FixYa.
Jun 12, 2010 | Acer X193W LCD Monitor
HP 1740 screen image rotated 90 degrees - how to move back
On most video cards the key combinations of ctrl+alt+left arrow, ctrl+alt+right arrow, ctrl+alt+up arrow or ctrl+alt+down arrow will allow you to rotate the screen display in any direction. Each key combination will rotate the screen in the direction of the key press.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 23, 2010 | HP Pavilion F1703 17" LCD Monitor
Desktop has rotated 90 degrees
keep pressing ctrl&alt and press upper arrow key
Apr 05, 2010 | HP w1907 LCD Monitor
Computer icons are upside down
use Alt + Ctrl + arrow keys
to reset the window normal position
use Alt + Ctrl + down arrow
hope this will solve your problem
Jan 02, 2009 | Dell Dimension 9200 PC Desktop
Display completely flipped to side
ha yeah i used to do this all the time, ok u press ctrl+alt+up arrow key
it will rotate ur screen.. make sure u click on ur desktop first and then press it
Jan 18, 2007 | Dell M990 19" CRT Monitor
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
