Hi!
The BIOS password is stored in CMOS memory that is maintained while the
PC is powered off by a small battery, which is attached to the
motherboard. If you remove this battery, all CMOS information (including
the BIOS password) will be lost. You will need to re-enter the correct
CMOS setup information to use the machine.
Or you can try using a Backdoor BIOS password, these passwords are typically used for testing and maintenance.
Manufacturers typically change the backdoor BIOS passwords from time to
time.For Toshiba, you can try using Toshiba as the password. I hope that helps.
