I have loaded a new Lexmark black cartridge , after using a coloured one and the massage says "incorrect cartridge, or something like that, what do I do to make it work.
    Guru:
  • 1,049 Answers
These printers can use a B&W cartridge and a color cartridge, or two color cartridges for enhanced color. I believe when you switch these it is supposed to detect automatically and change it in the driver settings. If it isn't the case for what ever reasonhowever, you should still be able to set it manually in the printer properties. If this fails, just try turning off the printer, unplugging the printer and moving it to another USB port, and turning it back on. Maybe you need to kick start the detection process.
Posted on Aug 08, 2008
I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
Aug 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
Lexmark printer x4690 says incorrect ink cartridge
1.check the instruction set here at the Lexmark site:
http://support.lexmark.com/index?page=content&id=HO3394&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X4690&searchid=1271735414583
Apr 20, 2010 | Lexmark X4690 Wireless InkJet Printer
I have lexmark x3580 printer i refilling the ink cartridge i have this massage in printer left cartridge Incorrect ( the black )
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 02, 2009 | Lexmark X3550 All-In-One Printer
Black 32 cartridge not working in X5410 printer
Did you purchase a "Lexmark" factory new cartridge or was it a third party cartridge made for a Lexmark printer.
The Black 32 Cartridge is listed for the family of printers. So either you have a defective cartridge (Contact Lexmark and ask for a warranty exchange of the cartridge) or return the cartridge to the store you bought it from and tell them your problem.
Jul 13, 2009 | Office Equipment & Supplies
Cartridge number for lexmark P 3150
#90 --> OEM Photo colour Ink cartridge (Lexmark 12A1990)
#20 --> OEM Colour Ink cartridge (Lexmark 15M0120)
#50--> OEM Black Ink cartridge (Lexmark 17G0050)
**OEM stands for: "Original Equipment Manufacturer
Hope this helps and please don't forget to give my answer a rating!
Thanks,
OpenSource13
Apr 06, 2009 | Lexmark P3150 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Jan 03, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark X5470 Printer
The messages Appears when the catridges are not inserted correctly........ Install the Colour Catridge on the Right Side and the Black should go in the Left Side...... Thanku
Jun 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
41 people viewed this question
jasbo
jasbo
