Question about Bosch Dishwashers
We have a Bosch Model SKT5102GB/07 and the problem is as follows; we load the dirty washing and start the washing process, the machine then goes through the full cycle of wash. Once finished you open the door and notice that the washing is still dirty and a large pool of water is laying in the bottom of the machine. We have had an independent engineer look at the machine and he has advised that the pump needs changing. Look forward to your reply, thank you. Regards Michael Ballard.
  • notesy Aug 08, 2008
    The pump isn't spinning freely so thank you for your help.
  • 13,433 Answers
Replacement parts are available here
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
on the narrow your search left side of the window
Select Bosch
Select Dishwasher
Select Pump / Pump Components
There are a few pages of pumps available but I didn't find yours with the model number you posted.
also read here about why a dishwasher cleans poorly
http://www.repairclinic.com/0088_9_1.asp#Level1_2
and also here about why water doesn't drain from the machine
http://www.repairclinic.com/0088_9_1.asp#Level1_4
Posted on Aug 08, 2008
    Genius:
  • 2,035 Answers
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
  • Bosch Master
  • 19,396 Answers
Your washing machine does not drain completely.
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.from repairclinic
Remove panels on Bosch washer
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC6400UC01/1794/0153200?searchedModel=WFMC6400UC&blt=
schematic of your machine...should help show the easiest way to take the panels off, by providing a map of clips and screws involved. also repairclinic.com or apdepot.com both have repair help videos that show the process.
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
I HAVE A BOSCH FRONT LOAD WASH MACHINE MODEL WFMC3200UC. IT WILL FILL AND THE LIGHT COME ON TO WASH AND THEN IT STARTS PUMPING OUT THE WATER.
B This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 02, 2011 | Bosch WFMC 3200 Front Load Washer
How do you load detergent into the Bosch axxiss washer
I'm assuming you are not quite clear as to which tray is which-
A quick way to find out is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
I think you also require an operating manual-
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Cheers,
John C
Mar 06, 2011 | Bosch Axxis WFL 2060 Front Load Washer
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
Jan 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 28, 2009 | Bosch Washing Machines
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Fitting washing machine boot gasket/door seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
May 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Dishwashers Logo
342 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
