Full screen display driver keeps failing
I don't know what motherboard, also when I go to adobe.com it freezes on my computer.
  • 44 Answers
Right click on desktop,select properits,settings, chk the following visible/not? 256 colrs,16 bit high,Trueclr 24bit.
if 3 r visible u can adjust u r screen area 1024x768
try &tell me
Posted on Aug 08, 2008
My display drivers keep failing the my computer freezes. it goes completely black then comes back again. Amd drivers installed.
The following needs to be done to first clarify the correct driver http://www.makeuseof.com/tag/how-to-find-unknown-device-drivers-by-their-vendor-device-id/
The next is a download that is free that will find any driver for you automatically free
http://www.driveridentifier.com/
Hope this works for you
IT Technical Manager with 10yrs experience
Apr 05, 2012 | Acer Computers & Internet
Results for: Microsoft Product: Windows Operating System; Version: 6.1.7600.16385; Event ID: 10111; Event Source: Microsoft-Windows-DriverFrameworks-UserMode Hi there, I found out after many screen...
There is severe corruption in the kernel (the core files) of your OS and the drivers are no longer loaded. Since you don't know what caused (probably some bad drivers since this motherboard is too old and doesn't have the correct Win 7 ones) it the only sure way to resolve it is to perform a full reinstall of XP.
May 09, 2011 | EliteGroup P4VMM2 Motherboard
System freezes-Video display=multi-staggered image(not legible)
It's either a loose connection from the motherboard to the video-display, or a partially-broken video-display, or the video-adapter in your motherboard.
Connect an external monitor -- if it looks OK when the internal LCD is "wavy", then your computer is fine.
But, since your say "happens to both screens", the most-likely problem is the video-adapter, which usually means that you will have to get COMPAQ to replace the motherboard.
May 26, 2010 | Computers & Internet
White screen "
Your display problem may be in the graphics controller on the motherboard. It might also be in the display itself, which contains a lot electronics. Yet another possibility is that the system is freezing up completely, and the white screen is the result.
Since it takes a while for the screen to go white, the trouble is most likely due to something heating up. I've fixed a lot of laptops that freeze up because the processor chip overheats. Sometimes it's because the fan isn't working, or the screws holding the fan assembly down work loose.
Hook up an external monitor to the laptop for testing. You might need to enable the external VGA connector with a function key before you'll see anything. If the motherboard is freezing up, the external monitor will quit as well when the laptop display goes white. If the computer keeps working normally with the external monitor, though, you know the trouble is in the graphics circuitry or display.
Unfortunately, it's hard to say for sure whether the motherboard or display is at fault. My experience has been that a completely blank display is usually a motherboard failure, but not always. Failures in the display itself usually cause lines or other problems with the image, but you still see something.
Replacement motherboards are often available at reasonable prices, but displays often are not. You may want to take this computer to a service shop and let them figure it out and give you a repair estimate. That way you won't wind up buying a part that may be costly and not fix the trouble.
I hope this helps you decide what to do. Thanks for using Fixya!
Feb 10, 2010 | Acer (9005210464), (64 MB) Graphic Card
Screen freeze
than your computer cannot supprt full screen movies..
Sep 15, 2009 | Compaq Presario 5000 PC Desktop
My Msi 865gm2 motherboard won't complete loading windows (any)
1.switch on your computer and press F8 to enter in safe mode of your XP
2. rightclick mycomputer,then properties,then hardware,then device manager, double click on the
display adapter
3. right click on the display adapter and uninstall it or disable it.
4. double click on sound & volume and controller, right click on the sound devices and uninstall it or
diable it.
5. restart your computer..
6. now your system will enter into Windows XP and it will detect your hardwares, if it ask for the drivers
just cancell it till your desktop screen appears...
7. uninstall the driver softwares which you have installed before for the display and sound devices...
download your required configuration drivers from the given link.
http://www.lostmydrivers.com/mainboard-drivers-and-utilities-drivers/msi/
Jun 20, 2009 | MSI 865GM2 LS P4/FSB...
No monitor display
this site
http://www.ultimatebootcd.com/download.html
is a link to Ultimate Boot Cd
this is a bin file to be burned as boot Cd
it contains a various tools including hardware check (google it!)
hope it helps
feed back
Apr 05, 2009 | HP Computers & Internet
V2dp and geforce vid card
You need to re-install the motherboard drivers for the onboard devices.
Sep 01, 2008 | Jetway V2DP Motherboard
Need a solution for failure of the ialmrnt5 display driver
Hello, I've Previously had this problem while using both the onboard and an extra pci videocard. The easiest way for me to fix it was usually going to the hardware manager, removing all drivers for all video devices, turning off the computer. Then when it is back on, do not let it reinstall the drivers, instead make sure your intel chipset has the newest drivers, if it does, then make sure the intel video card drivers are installed and working properly, then move onto the pci videocards drivers.
In this order, CHIPSET, ONBOARD VIDEO, ADDON VIDEO CARD (Is you use one). Reboot between each one to ensure the settings save.
Another strange problem i have every now and then, is that when i use an image (VERY LARGE IMAGE) as my desktop, the settings for the onboard intel "forget" themselfs, They just, stop, and the card always starts in 8bit mode with the lowest screen size. Changing the background image for my login page(NOT WELCOME SCREEN, ONLY LOGIN PAGE BACKGROUND) it continued to remember settings.
Other than this, the intel driver uses a dom+ service on the windows machine to read/write settings, if you have disabled dom+ or any of its dependencies, you may not be able to use the intel driver set.
Jul 07, 2008 | ASUS P4P800-MX Motherboard
Freeze on opening screen
Hi, It is possible that the CD ROM Drive is failing when the system hangs at this screen. You could disconnect the drive and see if it powers up all the time without fail. Also check all other IDE cable connections from the motherboard to the hard drive and any other drives as there may be a loose one etc.
Make sure you will not be voiding any warranty you may have with the machine before you do this.
Please ask if you need any help with this, and let me know how you go.
SeaJade
Jan 25, 2008 | Computers & Internet
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
