Question about Gateway M675 Notebook
I flashed the bios on my gateway m675 and it stopped working. It turns on but screen is blank. If I hook it up to an external monitor I can get into bios. Is there anyway to get it back to the way it was? Did I just completely screw it up?
  • 1 more comment
  • jgranados Aug 08, 2008
    none
    No I can only get into bios. I tried installing windows again but nothing happened. Is the motherboard bad? It was working fine but I flashed it with the bios version provided on their website and it stopped working.
  • easyq
    easyq May 11, 2010
    Once connected to an external monitor, does it fully work or can you get only in the BIOS?
  • 446 Answers
Pls check the bios set up externally if you mistakenly turn the brightness down, and correct it
or see if ther is any brightness button you accidentally pushed on the top of your laptop
or ther could be some problem with your LCD inverter or the LCD itself.
Posted on Aug 08, 2008
  • ariel santos
    ariel santos Aug 08, 2008
    once connected externally you can check out from bios if there is something that correlates to brightness , pls try
Black screen
Test it with an external monitor. If it does not work with an external monitor, then your motherboard is defective. If your laptop works good with an external monitor, then your screen need to be replaced.
Mar 05, 2014 | Gateway NV53A24u Laptop
Blank screen on laptop
Please test it:
1. Remove the hard drive and turn on the laptop. If the laptop display BIOS, then replace the hard drive with a good working hard drive,
If it the laptop screen does not display anything, then:
2. Test it using an external monitor.
- If the external monitor blank too, then there is something wrong with your laptop's GPU and or motherboard (you need to replace the motherboard)
Mar 05, 2014 | Gateway NV59C09U NV52 NV53 ......
Laptop screen is blank white gateway
I was say you will need to replace the screen. To confirm everything else is working hook an external monitor to the vga. You may need to press the FN key + one of the F# keys that may have an icon of a monitor to toggle the display to the external display. If everything works this way then replace the screen. You can usually find a cheap replacement screen on ebay.
Dec 19, 2012 | Computers & Internet
I have a gateway m675 and it has something wrong with the lcd screen. In the right hand corner the is a band about 2' wide and runs top to bottom. The colors are inverted looking that area and the tint of...
I would place bet on the LCD going/gone bad. If it works with an external monitor that is about all that is left. Google LCD replacement for screens.
Sep 03, 2010 | Gateway M675 Notebook
I turned on my m-675 yesterday and got the gateway green and black screen that just continued to stay there. After 5 minutes I used the control/alt/delete buttons to reboot my computer. Now, my computer...
From the information, that you used control/alt/delete to re-boot, I am assuming that you sensed that the computer finished the booting process. Meaning the tell tale sound (music) of windows booting was there, the hard disk whirling (blinking LED) for a certain period and stopping etc. If that is the case, (meaning you think your computer is capable of booting) probably you have a display failure. If you have a VGA cable connect that cable to the VGA connector (0n your laptop) and connect the other end to Desktop screen (monitor) or a TV screen with a VGA input. Probably you will see a display right away. If not press the Fn key and the key which changes the screen from laptop to external screen. This key will be marked either as CRT/LCD or with a picture( a square with two lines on either side of the square). If you get a display there, you may need to get a technician to change the screen.
Feb 11, 2010 | Gateway M675 Notebook
Screen does not com on gateway m675
use a flash light shine on screen if you can see the desktop real faint your invrter for screen needs replaced also you can hook up external monitor see if screen comes on on it if not then sounds like video card is shot
Dec 10, 2009 | Computers & Internet
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
M675 BIOS CHANGE
THE BIOS IS CORRUPT
MOTHERBOARD NEEDS TO BE REPLACED (300-1000USD) OR BIOS CHIP NEEDS TO BE REPROGRAMMED BY A PROFESSIONAL
Apr 15, 2008 | Gateway M675 Laptop
Gateway M675 creen problem
Yes you are correct and they are beggars to fix.  Your problem is fixable just ask these chappies:
http://lcdrepair.net
Oct 10, 2007 | Gateway M675 Laptop
Gateway M675 PRR Windows XP 3.0 GHz
Well, you can purchase a replacement bios chip online. Depending on your technical skills that option may be over your head, but there are companies online that will do it for you if you mail it to them. You could also purchase the chip and bring it to a local shop, though not all shops will have a technician that can do this for you. You could also see if you can send it to gateway for reflashing, it will probably be costly but may help you.
Oct 04, 2007 | Gateway M675 Laptop
Gateway M675 Notebook Logo
154 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
