Question about Dryers
WHIRLPOOL DUET DRY MOD#WED9400STO
I BOUGHT THIS FROM THE STORE (LOWES) AS A FLOOR MODEL "AS IS". IT NEVER STAYED ON. WHEN I TURN IT ON, IT SHUTS OFF AFTER A FEW SECONDS. NO ERROR CODE - JUST TURNS OFF. I HAVE THE EXTRA AMPS PUT IN BY AN ELECTRICIAN AS REQUIRED. BEFORE THROWING GOOD MONEY AFTER BAD, IS IT WORTH HAVING A REPAIR MAN COME?
EXTREMELY GRATEFUL FOR ANY HELP.
THANK YOU,
MARY
5 Suggested Answers
SOURCE:
  • 117 Answers
SOURCE: Duet dryer mod YGEW9200LW1 wont throw heat
coul be a fuse pn: 279973 or heater pn:3387747
I don't believe that is a heater because its a new machine.
You can get the parts at sears . com and search for parts.
If you open the botton plate of your dryer you gonna see at the right side the heater and screwed into the heater is a thermostat and a fuse.
Before replace the heater , make sure that your vent is cleaning otherwise its gonna blow again
Posted on May 09, 2008
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Posted on Apr 21, 2009
  • 23 Answers
SOURCE: Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Posted on Jun 19, 2009
When drying towels or jeans, my electric whirlpool duet dryer will turn off after 10 to 15 minutes of drying. Is this a heat sensor problem. Thanks.
First check the air flow by checking the outside vent hood.Any restrictions will cause the thermostat to shut down.
Apr 21, 2018 | Whirlpool Dryers
Age of Whirlpool Duet Serial Number CSP 2807389?
Age of whirlpool duet washer/dryer with sn csr2213663 model either ghw9250mt2 or gew9200lt1
Jan 31, 2014 | Whirlpool Washing Machines
My whirlpool duet dryer will not start. Power
You have to slam the dryer door shut. Sounds silly... but it worked. Guy said it has to do with it being stacked??
Jan 11, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Whirlpool Duet Washer will not start.
if you want to replace your washer you need to talk to lowe's store manager nobody else he or she will replace your unit. other wise you call for service. i think your washer need new main control board. good luck.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer is LOCKED ! I need it UNLOCKED !!
Push and hold the button that looks like a pad lock for three seconds and a beeping sound and then it should unlock. Depending on your model. Let me know.
Apr 06, 2009 | Whirlpool Washing Machines
Whirlpool duet front loader dryer....sensing light won;t shut off
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Sports unbalanced...
be sure the 4 screws that hold pedistal to bottom are tight ..next lower washer all the way down run all 4 feet up as far as possible next adj front legs until washer is firm on floor and has no motion when manually rocked ..tighten lock nuts to upper limit of legs to keep them from backing out if still have excess motion try adj 1 leg at a time while in spin ..also possible weak floor ..these machines are quite heavy and need solid flooring..also machine may rock some at low rpm but usually steady at max
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
104 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
