Question about Canon PIXMA MP510 All-In-One InkJet Printer
Printer I have a Canon Pixma MP450 Printer that keeps signaling a paper jam when there isn't one. printer reports a paper jam when there isn't one. I've checked for stray bits of paper inside printer; there aren't any. The signal came on out of the blue.
  • marou Dec 02, 2008
    All of a sudden my printer gave a message that there was a paper jam, but there isn't any paper in the printer! Please let me know how to solve this problem!!
  • 4,345 Answers
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
SOURCE:
My canon Mp 140 keeps Flashing E 3 after I removed the paper that was jammed.
From what I've seen, unplug this machine for about 15 minutes or just forget about it for a while and go back later and plug it in. make sure the paper isn't jammed. If the code persists, let me know.
Jun 13, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Error message - the paper is jammed
Check for either a small piece of paper that has torn and stuck, the paper sensor is triggering your "Paper Jam" message. If your printer has paper there for more than twenty seconds or if the printer is turned off and on and the sensor is still triggered it will report a paper jam. Next, check the sensor to see if it has come off the bracket when you pulled your stuck paper out of the printer. Also try and open the printer preferences in your Canon software, under the maintenance tab select quiet mode. Now re-download the printer driver and software, click on the link below to download and then restart your computer for the changes to take effect:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp450#DriversAndSoftware
Dec 15, 2010 | Canon Pixma MP450 All-In-One InkJet...
Errror code 6000
Error code 6000 appears when the paper jam, power off the printer and remove carefully the jam paper and power on the printer:
Nov 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
Keeps showing paper jammed, but no paper in it
just oil the paper feeder and wait for 24 hr. and you can start printing.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 25, 2010 | Canon Pixma MP450 All-In-One InkJet...
Sep 14, 2010 | Canon Pixma MP450 All-In-One InkJet...
Keeps saying paper is jammed
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Mar 06, 2010 | Canon Pixma MP450 All-In-One InkJet...
My canon pixma mp450 printer is displaying an error 5010
This is a carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 02, 2009 | Canon Pixma MP450 All-In-One InkJet...
Persistent paper jam error
How old is your model? This could be dirty rollers. See how I fixed that problem on this site: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if this helped. OK?
May 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Feb 21, 2009 | Canon Pixma MP450 All-In-One InkJet...
Printer thinks there is paper jam and will not print. There is no printer jam.
if there is no paper or small torn pieces of paper inside the paper detection switches must have a problem check paper switches for free movement of lever of the paper switches.and nothing broken or moved from it"s home position.
Mar 31, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
219 people viewed this question
Clive
Clive
old marine
old marine
Ekse
