Hi i`ve got an lcd panasonic but when i watch something it`s switch off for 3 secondes and switch on again in
  • Jason
    Jason May 11, 2010
    What is the model number of your Panasonic and what exactly is it doing that could help me with your current question?
It`s a panasonnic lcd model number TX-26LXD60
Posted on Aug 09, 2008
SOURCE:
Hi I ve a sony KDL-40W2000 stuck on stdby red light flashing 4 times the stop for 3 second ??any advice please
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 16, 2014 | Televison & Video
Samsung LCD TV Problem with Video
If this is a LCD, you have a failing LCD panel. Typical of older Samsung sets!
Jun 10, 2013 | Samsung Televison & Video
Plasma screen suddenly went out
its a lcd ? replace the lcd lamps or the inverter
May 04, 2012 | Panasonic Televison & Video
I have an old Sanyo 28" CRT widescreen TV. It works fine in PAL-50hz but when in PAL-60hz the colour constantly changes from colour to black & white and back again every few seconds.
I think the message is in your message - "old Sanyo CRT" (or old anything CRT, no discrimination towards Sanyo intended)
It's not LCD screen snobbery on my part either. I've a Panasonic 28" CRT I got new for £49 in a clearance only two years ago. OK it was a 2007 model but unused.
That will see me along nicely to avoid an LCD TV, I'll go for projection or LED screen when the Pana. dies.
However, this aint' getting us further along with yours.
Why do you need it to be in 60hz mode?
Is this something to do with viewing a USA NTSC system linked device?
Sep 24, 2011 | Televison & Video
Hello, I'm having an issue with my Sanyo DP42848 LCD TV. When you power it on the LCD panel turns on for about 2-3 seconds then immediately turns off. You can power cycle the TV over and over and every...
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Aug 30, 2011 | Sanyo DP42848 LCD TV
How can I make conference call or joint call fron vtech cordless phone
To make two-party call on your Panasonic phone and ask the person on the other line to wait for a moment.
  • Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
  • Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
    Regards
  • Jun 30, 2011 | Vtech Cordless 6041 Phone
    I can't make my canon mp460 do anything. little used i've just taken it out of it's box again and changed the ink cartridges but nothing. error 5010 showing.
    hi
    "Issue: ERROR LCD: Error Code 5010
    Solution: Press ON/OFF switch to reset the multifunction device
    Reset the device when it is not functioning properly.
    If the device is not functioning properly or to clear memory, reset it.
    1. On the operator panel, press and hold the button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
    2. Wait approximately ten seconds and then press the button again.
    3. Wait until the device has completed its cycling process before submitting another job request."
    or
    go to following link you will have more solution
    http://www.subnixus.com/error-codes/error-5010.html
    May 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
    How do i switch the tv from retail to home on the sony 40 lcd hdt
    I believe they are like the Panasonic's. Unplug your set for about 3 minutes then turn it on and watch the screen closely it should come up Home----Retail, I would say the arrow keys an the remote should navigate to the Home setting. Check your manual also, panasonic includes that in there set-up instructions.
    Mar 27, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    Plasma tv screen goes black once you turn it on. Only sound
    I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
    Aug 13, 2008 | Televison & Video
    The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
    PROFESSIONAL REPAIRER OF:
    * cd-vcd-dvd-ld player.
    * colour tv, Lcd/plasma tv.
    * projection tv.
    * prologic AMPS
    * Grill/microwave oven's
    * Digital proffesional camera.
    * Digital camcorders.
    * LCD/Digital projector.
    * Hi-Fi music system.
    * FAX machine.
    * printer/scanner/copier.
    * play station (PS1-PS2).
    * X-BOX360.
    DIAL..........: 9820380682
    Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
    Televison & Video Logo
    54 people viewed this question
    Top Televison & Video Experts
    Ekse
