Question about Garmin StreetPilot c550 GPS Receiver
Wont turn on
Gamin c550 is not turning on wots the problem?
  • gspencer Aug 19, 2008
    My garmin turns on but then turns itself off after it tries to load the map. I have tried to reset it.
Open and take out battery - after 10 mins return battery and it will switch on
Posted on Aug 22, 2008
  • garydubh Aug 22, 2008
    Try opening and taking battery out for 10 mins and then replace and try again. If this does not work - then problem is probably with charger
Turn on and word Garmin appears, then it says loading maps then it shuts down.
It sounds like you have a battery that is going bad. The StreetPilot is one of the older Gamins, and have been known to need new batteries after a few years of use. I would advise upgrading to a newer GPS.
Apr 25, 2016 | Garmin StreetPilot C550 GPS
Turns but wont start
do you have a spark ? is fuel getting to the plugs ? wot condition are the plugs in ? how old is the fuel ? let me know how you go budd ! P...
Dec 29, 2013 | Yamaha Motorcycles
Will not charge c550 garmin
OK, THANKS, THE MOST LIKELY PROBLEM HERE IS THE BATTERY IS DEFECTIVE.
Nov 11, 2009 | Garmin StreetPilot c550 GPS Receiver
Damaged the connection in the 12v car power to the c550. result was some fine brass fingers bent. The c550 will not switch on even though I know it is fully charged.How can I check if the c550 is still in...
You may have shorted out the battery. Have you tried pluggin the USB cable into the computer? If not, try this. The unit should turn on. If it doesn't, your battery may be damaged.
Oct 09, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin streetpilot c550 gps wont power up
Remove silver face plate by prying with your fingernail. Remove 4 screws, open and unplug the connector that the battery and speaker wires connect to. Wait 30 seconds and replug. Problem solved. Put back together and turn on. If this dont work, you have bigger problems.
Feb 06, 2009 | Garmin StreetPilot c550 GPS Receiver
WONT TURN ON W200I
is it charged?????
if no then charge it for 4hrs and see.
if it's still not working change the battery
Aug 10, 2008 | Sony Ericsson W200i Cellular Phone
Garmin
try taking it to halfords they will give u a ********
Jun 25, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin C550
Remove the front faceplate, (there is an indentation under the word Garmin on the faceplate that you can use to lift it with your finger nail). After removing the faceplate you will see a reset button on the right side. Press the reset and then try to turn the Garmin on.
Jan 30, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
95 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
