Question about Samsung CLP-510 Laser Printer
Paper wrapped around the red roller
Can anyone tell me how I can remove the paper that is jammed in the printer, it is wrapped tightly around the red roll, and I am not sure how to remove it.
    Master:
  • 521 Answers
Lift the cover remove all the cartridges and the drum unit slowly and carefully and slightly pull the upper side of the paper not the lowerside and if it is rolled completely you have to open the heater unit to remove if you donot have any technical knowledge do not try because the red roll you are taking is a costly thing,call the service technician and get it repaired that would be more cheaper.
Posted on Aug 08, 2008
Clear a paper jam on 3330
When you say "release it from around the roller", do you mean that the page looks like it is wrapped around the roller? If so then the fuser will possibly need replaced. Depending on how skilled you are you could try removing the fuser and disassembling it to remove the paper but it may not be possible. if you decide to try be careful not to tear the "roller". It is actually a fixing film, a thin mylar type product with a nonstick surface. It is easy to damage it and then you would have to replace the fuser for sure.
Jan 04, 2013 | HP LaserJet 3330 All-In-One Printer
Paper wrapped around inside of printer and no obvious way to remove it--too tight to get hands in and it appears there are no levers to loosen roller and pull paper out --next option is throw in trash and...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jammed message won't go away
Presumably this error follows an actual paper jam (whether the culprit has admitted it or not). The following is general advice that applies to paper jams in most printers, copiers, etc.
In my experience at least 98% of paper jam errors are because a piece of paper is still caught inside the printer. The remainder are generally due to a damaged paper jam detector (usually a small plastic arm which actuates a switch inside the printer) or less commonly a failure on the PC board which senses paper jams.
Please return to point 1 and look (again) for a piece of paper jammed in the printer. If the jammed paper was torn from the printer, only a small remnant has to remain inside the printer to generate an unclearable paper jam error.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab. Occasionally a page can wrap completely around a roller and be very hard to see. Be very suspicious of any 'white' roller' - check at the ends to note if the roller is actually a different colour with a complete page wrapped around it (generally then only removable by tearing other than complete disassembly by a professional). If paper was torn you may need a pair of tweezers and some determination to remove any small paper pieces wedged inside the printer. Ensure the printer is unplugged from the wall and avoid damaging any rollers or other parts inside the printer. Always remove jammed paper by pulling it in the direction of normal travel only. On rare occasions very serious paper jams may need expert service to dismantle and reassemble the printer.
After finding and removing all paper pieces, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test.
Mar 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Paper jam, unable to pull paper out
Yeah, I would be careful though and only take out what screws you have to and document where they came from.
Jan 08, 2010 | Samsung CLP 315 Laser Printer
Paper jammed between 2 red rollers in the back, can;t dislodge
The red rollers are probably replaceable, and therefore removable. Take a close look, and see if you can tell how they would be removed. It will either snap out, or you'll push it to the side and remove one end at a time. It'll be easier to pull the paper without the roller in the way.
While you have the roller out, you can clean it by wrapping packing tape around it a few times.
Jan 03, 2010 | Kyocera Mita FS-1920 Laser Printer
Paper will not feed unless it is helped and the red alert signal is always on. Can you help?
probably have some debris interfering with your 'paper path'. probably one of the paper pick-up rollers- check the path, try to remove debris, and try again! blinking red led is prob. jam warning! all it takes is a little piece of paper, or other debris wrapped around a "paper feed roller' to mess things up!
good luck!
Oct 08, 2009 | Samsung ML-2510 Laser Printer
Paper Jam - ADF
Open ADF cover
Lift up Pickup roller Assy
remove spring from pickup roller assy
Remove pickup roller assy gently pull it towards you
Carefully remove green plastic diverter
note this is held in place by 4 plastic pins 2 on each side
look in the opening for foreign objects.
( I have found labels, money, paperclips, plastic pieces,jammed paper in this area)
Aug 20, 2008 | HP LaserJet 3055 All-In-One Printer
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
HP 1100
I guess you should bring it to the nearest HP Authorized Service Center. Regards
Sep 11, 2007 | HP LaserJet 1100 Printer
Samsung CLP-510 Laser Printer Logo
196 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
