RCA scenium DLP 50''. The blue lights on the front (volume, channel, power, and options) all blink 5 times when I turn it on, but the tv doesn't turn on. It will do this anywhere from a couple of times, to several. Most times it turns on, but just doesn't "sound" the same.
  • 813 Answers
U have go with a professnol repairer
Posted on Aug 08, 2008
  • 13,434 Answers
I have been reading about the issue of blinking 5 times and it would seem to be a problem with the lamp.
replacement lamps are available from here
http://www.discount-merchant.com/RCA-D44LPW134YX1-Original-OEM-Lamp-P-N-265866-p/rca-d44lpw134yx1-lamp-265866.htm&Click=1466
you need to look for the spesific lamp for your model, you didn't mention about your model so do a search on the website ones you find out your details.
You can also look for a lamp in ebay, it may be even cheaper.
If the problem is not your lamp, well you got a spare and the lamp will fail someday.
You may want to contact rca direcly and get their opinion on the issue.
    Genius:
  • 1,011 Answers
Dear,
tell me, when it goes on then what about the pic on screen.
is it fussy or the perfect..
what happens if you try it again when it normally turns on.. is it still take the same time in the second attempt after sucessful turn on ..
regards,
  • SALMAN NASEER Aug 10, 2008
    is it clear to you or not get , how to solve it ..
    any further..
    regards,
    if not yet, then u have to check for any sound coming from inside the flyback or what about the inside condition of board..
    eg. capacitor, main filteration capacitor..
    regards,
SOURCE:
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium 44" HD44LPW62
it does not sound good take it to tv shop intermitten shut down or dead sorry
Apr 03, 2009 | RCA Scenium D34W20 34" TV
I have an RCA Scenium 61" DLP tv. Recently when you attempt to turn it on, it turns back off and the power button blinks three times. Then the tv will continuously attempt to turn itself back on with the...
sounds like you need to replace the color wheel but most of the time that is almost as expensive as the TV itself best bet for this problem would be to bring it to a shop and have it serviced
Mar 27, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
My RCA Scenium 50in. is not turning on!!
Its sounds as if the lamp has exploded or the color wheel has. I will post a link to a site that has a trouble shooting manual on CD called RCA DLP Disc #1 which covers every DLP in the ATC line which is what your model is. They have it either in cd form or they will email it. Its a very good resource for fixing your own set.
Jun 16, 2008 | RCA HD50LPW175 50" HDTV
I have an RCA Scenium HDTV DLP, Model HDLP50W151. Turned it on and went through it cycle, whining sound but the screen was gray. turned it off and then on again...no picture and there was no whining sound....
Sounds like the Color wheel on the Light engine has failed. Its a major repair. Contact Thomson at 1-866-465-7157 to find a local authorized repair center.
Jun 04, 2008 | RCA Televison & Video
RCA HD50LPW175 50 in. HDTV Television
Yes I should be able to help you figure it out. First look on the rear of the set to check what the chassis number is. Should be an ATC 336 but it might be a ATC323 let me know the chassis number and we can go from there on diagnosing the problem
Feb 15, 2008 | Televison & Video
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Ekse
