Question about Acer Computers & Internet
I have an ACER ASPIRE 5720 laptop - it is less than a year old and it is showing the memory is full - the memory is meant to be 32 GB and from what I can see from the programme menus there is less than 4 GB on it but I keep getting the error message that the memory is full and I am unable to download any further info onto it.
  • 176 Answers
What is u're OS ?!
if windows u probably have a "recycle bin" that is full, or "recovery" backups that fulled the drive ... try to delete them
Posted on Aug 08, 2008
  • 2,351 Answers
Hi j0shuatsb,
Acer like many other manufactures seem to design their system to fail or have issues just after their 1 year warranty is up. Like other Microsoft windows operating systems, when you receive an error message that you're memory is full. This does not mean you have run out of RAM = memory. You're notebook can only run a max of 4GB of memory. The error message refers to hard disk drive space. Depending on you're operating system, windows will lock out so much drive space so it can move about. All notebooks also have a hidden partition which holds drivers & programs used in combination for running the system restore.
This hidden partition can range in size from 2GB up to 4GB.
This also lessens you're total hard disk drive space. Bottom line is there is nothing wrong with your memory.
What you need is a larger hard disk drive. Notice the Technical specifications from this link:
It does not show what size you're SATA hard disk drive is.
Since you are still in warranty, now would be the time to increase you're drive size. On another note, if you're HDD is the standard 160GB than there is an issue with your current HDD.
Please run a full system virus scan.
Suggest you back up all you're personal data on to a DVD & run you're system restore CD including a format to help you regain you're HDD full space. A temporary fix would be to uninstall any non needed programs through Add/Remove programs. This should free up some space. Many Acer programs you do not use at all or need should be the first to go.
Acer aspire 5720, after erasing everything, still getting "low disk space" message. beyond disc cleans & system defragmenting...Any suggestions?
Hi Brandon, You can try cleaning the temp files Click Start >> Run, then type %temp% Enter, then delete everything in that folder.
Please download CCleaner to clean up your registry
CCleaner Download
Mar 11, 2014 | Lifetime Acer Aspire 5720-4126 Replacement...
Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
  • CPU Section:
  • Microprocessor Full Name:Intel Core 2 Duo processor T5250
  • Microprocessor Manufacturer:Intel
  • Microprocessor Speed (GHz):1.5
  • L2 Cache (KB):2 Mb
  • Frontside Bus (MHz):667
  • Memory:
  • Memory Speed (MHz):667
  • Memory Type:DDR2
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb
  • Hard Disk Drive:
  • Hard Drive Capacity (GB):80 Gb
  • Hard Drive Type:S-ATA
As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
Oct 18, 2010 | Acer Aspire 5720 Notebook
Where are memory slots on Acer 5720-4126
They are located on the base of your laptop. Here is a link to the manual for your laptop.
It shows where it is and how to change/add the memory.
The drivers for your laptop are there also
Jul 11, 2010 | Acer Computers & Internet
I want to update my RAM
 You probably meant 3.6 GB which means that you have installed a 32-bit OS which can't recognize more by design. If you want to have all memory recognized and utilized you will gonna have to reinstall again, this time using a 64-bit OS.
Jun 05, 2010 | Acer Aspire 5520-5908 Notebook
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
Spreading brown stain on screen
your LCD panel is damaged, if it is only a year old it should be under warranty, it needs to be repalced.
Jun 11, 2009 | Acer Aspire 5720-4230 Notebook
Acer 5050 5430 not reading the correct aomut of memory
Windows 32-bit operating systems cannot physically see 4 GB of memory. The most you can see is 3 GB. And, assuming you have onboard video, 1/2 GB is going for video memory, thereby showing you only have 2.5. The only way to solve this is to install either Windows XP or Vista 64-bit operating system to fully utilize your 4 GB of memory.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Acer Aspire 5050 5430 Laptop
Computers & Internet Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
