Click start control panel
administrive tools computer management device manager scroll down universal
serial bus controllers you should see a yellow question mark?
right click to reinstall
drivers
if you can see
your usb drive but its not working
ports(com&lpt)right
click update driver if this fails to fix the problem
check the USB leads that
attach to the motherboard usually red white green black make sure they are
securely seated and have no dust build up on them dust will cause static and a
lot of unforeseen problems for a computer and its parts also
scroll to disk drives if
you can see your drive + to expand right click you should see options update
driver disable uninstall scan for hardware changes
select properties you
should see options in the general tab to troubleshoot policies volumes driver
and details under the driver tab you will have the options to check the
driver details update driver rollback driver or uninstall
hope this helps
How much memory is already installed? Windows 32-bit can only recognize max 3.5Gb of Ram.
