I have run into this issue a couple times recently with this exact model & a handfull of other various Monitor's , http://www.filefactory.com/file/cbc1b15/n/ADIMonitorV97.zip , here is a link to the drivers I used on Windows 7 64 bit Home Premium , I installed using compatibility mode ( right click the .exe , select properties from the drop down menu , select the compatibility tab , select run in " windows xp sp2 " mode & check the box at the bottom " run as administrator " . Also you might want to disable " UAC " ( open the control panel , select users , select change UAC settings , drag the slider all the way down to disable , then click apply & reboot your pc for it to take effect .
