Photos from pc to sd
I want to copy photos from my pc to a sd for use in a digital photo frame.
  • gg_alabama Aug 08, 2008
    Thanks ~ I was trying to find a way to download without having to buy another piece of equipment. But looks like I must.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
The easiest way to do this would be to buy a card reader for you PC. You can buy an external one that plugs into the USB port.
Another way is to used a computer with a SD reader and upload it into a flash drive. Once you have the flash drive, you can upload the pictures using your flash drive into the frame.
Posted on Aug 08, 2008
How transfer photos from computer to pandigital
First...make sure the format of the photos is
compatible with the frame...JPG would be the best
choice.
I'm guessing the frame has an SD memory card?
Do you have an internal or external media reader?
If_Yes_try the following steps......
Insert the SD Card in your media reader and go to...
Start / Computer.
The media reader should be recognized as one or
more Removable Disks and each will have a drive
letter.
Example:
Removable Disk (F:)
Removable Disk (G:)
Removable Disk (H:)
Left click each Removable Disk until you reveal the
Root Directory of the SD Card.
(If not....the frame (connected by USB) may be listed
as a Removable Disk)
OK...now that you know the drive letter...if you right
click a selected group of photos or a complete folder
you should be able to choose...Send to / Removable
Disk (?:)...this should copy the photos to the SD Card.
Be sure the photos are in one or more folders because
the number of photos you can copy to the root directory
will be very limited. And you will receive the following error:
"Cannot copy XXXX: The directory or file cannot be created"
Jan 31, 2015 | Photography
How to put photos onto SD cards
In Windows, click on Start/Computer. A window opens showing all the drives connected to the computer. Under "removable drives" locate the SD card. Hover your mouse pointer over the SD card icon and it should tell you how much free space is on the card. If necessary, delete some photos or other data to make more space available so you can add the photos you want. If there's already plenty of space, try formatting the SD card in either ex-FAT or NTFS format. Then try copying the photos again. If the SD card does NOT in appear in removeable drives then the SD card may be faulty. Try a different SD card.
Nov 04, 2014 | Philips 6.5-Inch Digital Photo Frame...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
How do you add new photos to the digital picture frame?
Most digital photo frames come with an SD (memory) card that you can plug into a computer and copy the photo's you want from the computer to the memory card. Once done you pop the card back in the frame and your done.
Please be aware that the SD card maybe of limited capacity so you might not be able to get all the photo's you want on it unless you purchase a larger capacity card.
Regards.
May 26, 2010 | Coby DIGITAL FRAME COBY DP102 RTL
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
Nov 30, 2008 | Computers & Internet
I bought a technika jp07 photo frame but when i put the sd card in it comes up no playable file. i tried the same sd card in another photo frame and it works fine. please help mrs bev bartram
It seems that it's not about the size of file or resolution of the photo!
I was given one of these yesterday. I copied my photos on to a 64mb SD card of unknown make. They display fine on my PC but on my Photo Frame I get the "no playable file" message. I tried changing file size etc but no good.
As a last resort I copied my same photos on to a 2GB SanDisk SD card and tried that. It works fine. So my guess is that these photo frames are picky on what SD card they'll accept.
A pity the manual doesn't tell you so!
Nov 13, 2008 | Cameras
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
