Question about Numark Audio Players & Recorders
Numark tt1625 keeps on jumping
Hi there please could you help me just bought a numark tt1625 when i put a record on it plays 2 secs then jumps any advice please
  • 515 Answers
If your weight and such are correctly set, then the only other issue might be a worn stylus, or your tonearm might be damaged.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Posted on Aug 10, 2008
The plate on my numark tt USB is wobbiling
I find it hard to believe some of these answers. If the platter is wobbling, if you remove the platter, you'll find the spindle the platter rotates on. That will probably be loose. At the bottom of the spindle bearing, you will find a nut. Tighten that, and you should be in business. If you have further questions please visit my website at audioserviceclinic.com. You may contact me there.
Apr 26, 2015 | Numark ttUSB Turntable
My need on my turntable jumps around on my records
If it keeps sliding in one direction, it probably needs an anti-skating adjustment or to be put on a level surface. If it jumps all over, the stylus weight is probably too light or the surface it's on isn't stable enough.
Sep 24, 2012 | Sony Audio Players & Recorders
Numark IDJ 2USB Flash Drive issues
use the lexar brand jump drive, they tend to work better the the dj station. i have a 64GB jump drive with 3,000 songs on it and it works great with no problems.
Jun 21, 2012 | Numark iDJ2 - DJ iPOD Mixer Docking...
I have numark tt 1610 decks, checked needles on both decks and they are both fine 1 of the decks however keeps skipping even when I try with both needles and different vinyls I've taken the weight off,...
Examine the cantilever very carefully - you sure that the stylus is there? Not uncommon for the lever to be perfecto but the stylus is gone. So when you go to play a record the arm slides all over the place!
Sep 23, 2017 | Numark TT1610 Turntable
How do I get my sound from my Numark TT1625 to play through my DVD/CD speakers?
You need a magnetic cartridge preamp. You then plug your turntable into it and the box into the CD/aux imput of your amp.
May 21, 2010 | Numark TT1650 Turntable
My tables (tt1625) slow down after about 20 min of play, or 10 min harder scratching.The sound quality is still great but I really want to scratch more.What can I do?
i wish i could help, it seems no-one can answer this, ive just scowered the internet, coz i got the same problem, but nothing! probly just need a new motor! sounds expensive
Jan 19, 2010 | Numark BATTLE PAK v.4 Turntable
When I scratch with my numark tt1625 its very slow to spin again
Try Changing The Slipmats Gemini Slipmats Are More Slippery Than Standard Numarks I Use ThudRumble Frosted Plates In Place Of My
Original SlipMats On My 1650's
Numark tt1625 turntable wavey sound
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Numark tt1625 speed issue
hi nikki,
when you say ages to get back to speed how long is that exactly? even on my technics for cueing i give a slight throw to hit my cue points.
also your slip mat may be an issue. do not use the rubber mats use the soft nylon foam one that came with it only.
Feb 27, 2009 | Numark BATTLE PAK v.4 Turntable
My numark tt1625 turntables keep slowing down
If you could be a little more specific, we might be able to help you out better.
Does it slow down, when you do anything, or after a long period of time of being on/used? Or as soon as you turn it on, it slows down?
Any specific information would be greatly appreciated.
- Davis
DJ Pro Audio
www.djproaudio.com
Jul 14, 2008 | Numark BATTLE PAK v.4 Turntable
371 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
