Question about Lenovo 256MB ATI X1600 Pro VGA DVI-I TV-out PCI-EXPRESS Dual Head Graphics Ada FRU:41T2725 PCI Express Graphic Card
Ram Sharing I have a lenovo 3000 G410 and together with it is a Mobile Intel 965 Express chipset that has a 256 mb memory, my Ram is 1 GB and at the time I added another 1 Gb ram my system total Ram is now 2 GB and my intention of adding was to increase my laptops video memory to like what I did with my compaq which is a lower end model..Now my video memory is still the same that is 256 MB aand it has not change even after I added the 1 gb ram..and in the bios I cannot see any option to share it..can you please help me solve this..thanx a lot..inaki
  • 446 Answers
There is a hardware compatibility list for all pc, chances are your pc have exceeded its maximum allowance for any upgrade, even though you have installed a higher value or capacity of RAM.
try reinstaaling once again and make sure you have the right speed allocation on your RAM , make sure that the ols RAM and the new one has the same PC___
Posted on Aug 08, 2008
SOURCE:
Pci flash memory driver comes under
A) Chipset drivers
Unless there is a specific driver listed.
To explain;
You have a motherboard chipset on your motherboard.
The technology used on the Lenovo 3000 C100 Notebook PC, for it's motherboard chipset; is a Northbridge chip; and a Southbridge chip.
[The motherboard chipset is an Intel 915G Express, that is the Mobile version,
http://ark.intel.com/products/27733/Intel-915G-Graphics-and-Memory-Controller
This motherboard chipset has a Northbridge chip, and a Southbridge chip ]
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Does not mean PC. Personal Computer.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Northbridge chip handles the Faster capabilities of a computer.
Processor (CPU), Ram Memory, and HIGH-speed graphics.
HIGH-speed graphics is the AGP technology, and the PCI Express technology.
It is NOT a graphics card inserted into a PCI slot, nor is it Integrated Graphics.
The Southbridge chip handles the Slower capabilities of a computer.
Anything connected to the;
PCI bus
Integrated graphics.
IDE bus
SATA bus
USB bus
Ethernet
Audio (Sound)
For additional questions please post in a Comment.
Or click on Reply at end of solution.
Regards,
joecoolvette
May 13, 2013 | Lenovo 3000 C100 Notebook
Correct Graphics Driver for Windows 7
try a downloadble programme like driver easy or similar.
Apr 24, 2013 | Computers & Internet
Will 9500 GT either 512 mb or 1 gb work on intel la crosse D865GLC board..?? it has 3 pci slots 32-bit long..
Yes you can.
For 512 Mb RAM you can use a single 512 Mb memory module or two 256 Mb memory modules.
For 1 Gb RAM you can use a single 1 Gb memory module or two 512 Mb memory modules.
Apr 13, 2011 | Intel Desktop Board D865GLC (MBIND865GLC)...
I cont play 3d games graphic card is there in acer aspire 4720z
* The system configuration of Acer Aspire 4720Z PC Notebook is :
160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
* Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
* But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
* If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
* If you want to upgrade the memory (RAM), you can check this site : http://www.laptoppartsexpert.com/c-60093-acer-aspire-4720-series-as4720z.html
please rate this advice if it helps
Nov 17, 2010 | Acer Aspire 4720 Notebook
How do I find my graphics card on acer laptop 4720z and change settings to best play games
please rate this advice if it helps...tc! :)
Jan 13, 2010 | Acer Aspire 4720 Notebook
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
Can i upgrade the video card intel 915 gm in my asus eee pc 904hd with 10 inch screen to suport the aero theme in windows vista
There is already a reply for this :-
Intel will support the Windows Vista Aero desktop theme beginning with the Intel 945G/GM Express chipset and Intel 965 Express chipset families, as well as with future desktop and mobile chipsets.
Hope that would answer your solution.
Upgrade and get it fixed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 23, 2009 | ASUS COMPUTER INTL EEEPC904HABLK010X: Eee...
Probably a sound card problem..
i solved it already..
i just lowered the sample rate and the bit rate and now i can play songs and freecell at the same time..
Jun 28, 2008 | Toshiba (4CH-VOUT) Sound Card
To u my friend
nothing much buddy ...
here are some details below find the right one and take it
Model No: TM 2403NWXCi
Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
RAM: 256 MB DDR2 400 RAM
HDD: 40 GB
Optical Drive: DVD-Rom/CD-RW Combo Drive
Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
Graphics: Intel GMA900
Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
Weight: 2.38 KG
Battery: 6-Cell Lithium Ion Battery
O.S.: Linux
Warranty: 1-Year Global Warranty
Price: Rs. 27,999*
Model No: TM 2424NWXCi
Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
Model No: Aspire 5002NWLMi
Platform: AMD Turion 64 ML-30 (1.6GHz)
RAM: 256 MB DDR333 RAM
HDD: 60 GB
Optical Drive: DVD-Dual Double Layer drive
Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
Graphics: N.A.
Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
Weight: 2.9 KG
Battery: 8-Cell Lithium Ion Battery
O.S. : Linux
Price: Rs. 37,999*
Model No: Aspire 5004NWLMi
Platform: AMD Turion 64 ML-34 (1.8GHz)
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Model No: Aspire 5502ZNWXCi
Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
HDD: 60 GB
Optical Drive: DVD+CDRW Combo Drive
Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
Weight: 2.38 KG
Battery: 6-cell Battery
O.S. : Linux
Price: Rs. 40,499*
Model No: AS 1641NWLMi
Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
RAM: 256 MB DDR2 533 RAM
HDD: 60 GB
Optical Drive: 8X DVD-Dual Double Layer Drive
Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
Weight: 2.38 KG
Battery: 4-cell Battery
O.S. : Linux
Warranty 1-Year Global Warranty
Price: Rs. 42,499*
Apr 14, 2008 | Computers & Internet
Lenovo 256MB ATI X1600 Pro VGA DVI-I TV-out PCI-EXPRESS Dual Head Graphics Ada FRU:41T2725 PCI Express Graphic Card Logo
174 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
