Question about Acer Computers & Internet
Wireless LAN no access with wireless LAN at Hotel Bremen(germany)
    Scholar:
  • 144 Answers
Do you have acces to unprotectd networks?
Is your wireless switched on?
Try unchecking your proxy in properties under connections TAB (tools, internetoptions, TAB connections).
Posted on Aug 08, 2008
I am trying to connect to xbox live at a hotel and it says i do not have a sufficient mtu setting. i cant change the mtu setting because it isnt my network and i dont have a modem in the hotel room
Hotel wireless networks are not the best to be playing games on since everyone in the hotel has access to it and slows it down making the internet connection slower and unable to handle online gaming. You will just have to stick to single player games or split screen until you get home.
Jul 24, 2011 | Microsoft Xbox 360 Console
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Need basic step-by-step instructions on how to install my router.
  3. Reboot the PC.
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I'm using a Toshiba C 1.8 14X256M 20 CD Satellite A10 system unit model no psa10L... I do not know if I can connect to wireless lan in hotels. How do I know if my laptop has wireless modem? And if it...
I just googled "toshiba a10" and looked at the specs. It has wireless support but no wireless built in. just buy a 802.11 wireless dongle and plug it into the usb ports and away you go.
Oct 10, 2009 | Computers & Internet
We have a Intel wireless-G 2.4 GHz and everything was fine until we moved last week. Now the internet works on this computer that is directly hooked to it and the wireless seems to work but I can't get...
Your Intel wireless-G 2.4Ghz is defective, all you have to do is test another wireless LAN to make it sure that is working via USB panel.
I encounter this kind of problem and wish it would be the same like me. Usually this kind of problem cannot see itself that is defective but it is working good to your PC.
Just try a new wireless LAN if might work.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 25, 2009 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Cant connect xbox360 to hotel wireless router
hotels have a special program for routers creating their own community network, you have to access that through a link on the computer and you cant do that through the xbox. the hotel fucked you
Aug 04, 2009 | Microsoft Xbox 360 Console
Setup 3Com Wireless LAN Access Point 2000 as a wireless bridge
Just u enable the DHCP in ip setting option.
then your extender PC shuld enable the dhcp automatically
Mar 27, 2009 | 3Com Wireless LAN Access Point 2000...
Wireless network connection problem
Ok with a peripheral on USB or on PC card bay you can try to connect to a Wireless lan:
Please check this tip on the subject
To connect to an existing WLAN you must be sure your wireless card is working: I assume you installed all the related sw coming with the wlan card.
Using the card installed driver check card is enabled and running (in Control Panel/Network connection should be visible and enabled)
Then you can connect to an open Wi-Fi HOTSPOT or to your WLAN you configure with a router connected to your internet modem.
  1. To connect to an existing HOTSPOT: find a location where you know a wi-fi access point (HOTSPOT) is active: Internet cafe,, library, airport,, station, hotel etc.your card should be able to find the existing network when you select "show existing network" in wlan driver. Connect if network is "unsecure" (= no password or key is required) or ask for password if you can get it for a fee (hotel)
  2. To connect to your home or office WLAN be sure to use a router (or access point) with same standard of your card (802-11G or B or A or N) with same security protocol (WEP or WPA) and configure your router Internet access BEFORE wireless access. Connect your PC to your router using a LAN cable and be sure you can browse through the router.(contact your ISP for router specs if you need it: PPOA/E and other). Follow the tip and your router doc for settings
Jan 14, 2009 | HP Compaq Evo n610c Notebook
Wireless internet service
Rather than "...purchase a wireless card..." since "...have no external slot..." and "...have a built in wireless card..." why not consider a WiFi AP/Router that can either serve as Access Point, Router, Bridge. Repeater (such as a LinkSys WRT54G). Such a unit if configured right will work in either a wired or wireless environment.
Perhaps your foremost concern should be; will there be a wireless Internet Provider/service within the immediate vicinity of the hotel. This of course depends on the location (country) and available service. In some countries/locations, the wireless ISP Provider bundles in their package the needed hardware. It is almost a rarity nowadays for a hotel not to have some sort of Internet Access even if just a dial-up. They may not share it with guests but most likely they are capable.
Alternately, you can try looking around for a public Internet Cafe and negotiate for a temporary WiFi access while staying in that location.
In some extreme case where the ISP requires use of a PCMCIA card and the laptop does not have such bus/feature or port, there are on the market an adapter/ converter that plugs to your USB port and the other ends will accept a standard PCMCIA card. Some examples of this device may be found here, here and here. The last was specifically designed for Broadband applications as well as Bluetooth.
Hope this be of some help/idea. Pls post back how things turned up[ or should you be in need of further information.
Good luck and kind regards.
Nov 07, 2007 | Computers & Internet
Can't get it to talk to my LAN in ad hoc mode
Is the AP connected to the router using a ethernet cable? Are you having similar issues when you connect wirelessly to the wireless router?
Feb 11, 2007 | D-Link AirPro DWL-810+ 802.11b...
Computers & Internet Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
