Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Distorted colors & distorted sound from monitor speakers
I received a complete computer set-up from a friend...running XP...all is in working order with the exception of the color resolution is distorted....it is glaringly evident in reds which look very blue....white skin tone in pics appears olive or brown....
Secondly....voice comes across sounding like munchkins or chipmonks....
Can I remedy the situation please?
    Genius:
  • 1,011 Answers
Dear,
first of all, select the default theme of your pc.
then check the resolution, try to check it with different resol. except recently selected.
have your VGA driver installed properly, if yes, then try to install your monitor by checking it to the destop, right click, properties, -->setting---.advanced---. monitor---> properties and try to update driver and let it install the compatible one..
regards,
Posted on Aug 08, 2008
    Genius:
  • 2,785 Answers
Plz follow the steps of expert s4u311, if the problem is not solved then check your speaker are placed near the monitor if yes then remove it. plz remove the monitor cable going to cpu and check is there any bend pin,if yes then straighten it. if after doing all your problem is not solved then remove your ram and resit it.
  • 813 Answers
Remove reinstall your garaphic (vga) driver
BLOWN EHERNET IN PC, USING IT WIRELESS BUT COLOR IS DISTORTED. PC OR SCREEN?
Could be either one. Best bet is to find a friend to try out your monitor on his computer or try his monitor on your computer.
Aug 17, 2014 | Computers & Internet
Sigmac NE32AB1 Sound Distorted
Interference. Separate wiring in back, so there is no cross-talk of signals. If speakers are failing, go to walmart and buy a new set, <$20.00, hook up and sound is great.
Feb 13, 2014 | Sigmac NE32AB1 32" LCD HDTV
Screen colour distorted
Your monitor needs to be replaced more than likely.
Try using another monitor to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor shows the distorted colors, then your video card inside the computer is bad.
May 22, 2012 | Toshiba Computers & Internet
Monitor freezes up with multicolor wording or distorted images
Sounds to me like a few possible things...
1) Bad connection to the monitor, check the cable connection, if you see or suspect any damage, buy a new monitor or test with a friend's monitor.
2) Video card could be bad, if it has a video card, you could simply buy a new card to see if it will fix the problem. If the video port is attached to the motherboard (meaning onboard video), the motherboard could be damaged.
3) The motherboard could be bad. Sometimes fried motherboards will garble the screen like this on bootup.
Mar 25, 2009 | IBM Computers & Internet
Sound Distortion claimed by the recipient of calls.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Feb 22, 2009 | Logitech QuickCam Pro 5000 Webcam
Screen appears squeezed from left and right sides
Sounds like the video card settings are over-riding the monitor settings. Go to display settings in control panel, and try the one that says "recommended". The other thing I have found out is sometimes the monitors start doing strange things before giving out completely.
Nov 30, 2017 | Dell E771a 17" CRT Monitor
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Sound from monitor speakers distorted and high-pitched
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
Center speaker
I had the exact same problem. In order to "almost" balance the center with the other channels I had to give the center +12db gain and the other channels -12db. So after I got that far with level calibration I tried some tv sound, well the center although was playing sounded like the highs were missing and a bit distorted. This is the good part, I turned the volume all the way up real fast, somewhere near max something fixed itself, the center became very loud. Now it works just like new. Hope this helps. BTW, the problem existed the same for sub channel, so when the center started working so did the sub.
Jan 08, 2008 | Onkyo TX-NR801 Receiver
Distorted picture on 20 inch monitor
second problem some unit on the board in the monitor has gone bad return it for an exchange
first problem the display setting need to be set correctly
Dec 28, 2007 | Acer AL2016W 20" LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
74 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
