USB/Installation problem. I have this problem with this brand new webcam I bought the HP Elite Autofocus Webcam. I thought maybe the webcam was broken when I tried installing it I even went back to bestbuy to get another ne... and that wasn't it.. there must be some setting on my computer that won't let me install it... I turn on my computer and the Magic-i program comes up and says to re-install it cause it wasn't installed correctly, so I do that but still the same problem then I try out my webcam on the Webcam companion 2 that came free in the installation cd.. and it says my webcam isn't installed or its in use by another computer.. but I only have one computer I really need some help on installing it I think i've tried almost everything to get this webcam to work. driver for webcam topsun
  • Saadation Aug 08, 2008
    I have problem for driver webcam topsun
    President:
  • 8,637 Answers
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 13, 2009
My HP Elite Autofus webcam works fine when recording/playing back to my laptop, but the audio does not reach Skype
Open Skype, click "Call" and select "Audio Settings..."
Click on the pull down menu next to Microphone and Speakers to make sure Skype is setup correctly.
Apr 14, 2011 | HP Elite Autofocus Webcam
Straight noise in the recorded clip
Make sure the webcam mic is set as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
You may be getting feedback from your speakers to your mic
Check by using a headset
May 05, 2010 | HP Elite Autofocus Webcam
Hi i want a driver for my hp cam its cif chip usb web cam
1st You download Webcam Driver. HP Webcam Driver After this install the webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Nov 23, 2009 | HP USB Web Camera
I just bought the cam and the disc that came with it dont want to read when inserted model ez-307 new brand.i dont know what to do to open up the disc to get it download,maybe if i hit run it might but i...
1st You download Webcam Driver. Ezonic Webcam Driver After this install the webcam driver in the system.
Jul 13, 2009 | Ezonics EZCam PRO Webcam
Cant open my HP webcam after installation
you should go to hp and make sure you get the driver and the program for the camera and uninstall what you put in and try the new versions.
pay attention to the path where it installs to and go to that folder and look for the .exe that starts the prog.
Jun 19, 2009 | HP Webcam
Brand new HP computer with Integrated Webcam Not working
Do you have the USB cable connection from the monitor hooked up to your computer? If so, are your USB ports configured properly?
Your computer should alert you with an audible tone indication whenever you connect or disconnect the webcam USB cable. If it is not doing this, The webcam itself may be defective.
May 30, 2009 | HP w2558hc 25.5" Widescreen LCD Monitor
LOST INSTALLATION DISK FOR WEBCAM
Here is the website for the company that makes these:
http://www.mingjong.com.tw/eipe/front/bin/ptlist.phtml?Category=100012
That model is not listed as the M6217T, but there is an M6217. You can also see if the Smart Camera Version 2.1.1 software will work for you.
May 17, 2009 | Micro Innovations HP USB 1.1 Entry Level...
Need a driver for my USB web cam
did you check on hp web page
Feb 11, 2009 | HP USB Web Camera
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
