Cant access the the menu on a panasonic 42" plasma and the up and down channel buttons dont work to change channels.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
Easiest way to bypass that is buy a different remote. There are several programmable remotes out there. But since your tv is pretty fancy. I would go with Logitech Harmony. While they are little more expensive. They also do a lot more.
Familiarize yourself with the different options the remote has and pick which that works best for you.
Posted on Aug 08, 2008
Service menu tv 42px75u
Sounds like an issue with the remote. Try other functions, too. You may need new batteries.
Nov 30, 2013 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Dont have the remote control cant turn to channel 3 or 4 dont have a menu button
Isn't there a channel Up/Dn button at the front panel of this TV. It should be there. Only Menu button is not. There is Ch up ' Ch Dn and Vol Up ' Vol Dn buttons, beside a power button. Even pressing the channel Up ' Dn button, the channels cannot be changed, check the micro switches inside the TV. Replace them all at one time. You ave to open the TV to access these components.
Aug 02, 2012 | Sylvania 6719DF 19" TV/VCR/DVD
Panasonic tv changes channels
Check your remote control for a stuck button. Like 7. If it is ok, then I would suspect your main board.
Apr 10, 2012 | Panasonic TH-42PX75U 42 in. Plasma...
How do you delete unwanted digital channels we have lost our instructions for panasonic viera TH-42 PX7A
Go to Setup, Tuning Menu, Analog Program Edit, Select the Channel to Edit and set it to skip the channels you don't want to see anymore.
Mar 01, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Problems with getting channels locked in on our plasma tv
Yuo can change the pin # even if you don't know the old one then you can can turn off with the new one.
Press the 'MENU' button on the remote control.
Press cursor down to select SETTINGS.
Press cursor right twice.
Press cursor down to select MENU PREFERENCES.
Press cursor right.
Press cursor down to select CHANGE PIN.
Press cursor right once.
Enter code 0711 if you have don't know yours
Enter a new four digit PIN using number buttons. Number combinations from 0000 to 9999 are valid.
When prompted to confirm PIN, enter new PIN again.
Press the 'MENU' button to exit the menu.
Feb 22, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Finding AV channel to connect DVD to TV
first check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
Nov 16, 2008 | Sanyo DP42746 42 in. Plasma Television
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
No channel available
Unplug it for 10 secs and plug it back in then wait 10 more seconds and turn it on with the on/off switch. Unplugging makes it reload the firmware, but on/off does not. If that doesn't work try a factory reset. For my Panasonic you do this. Open front door to get at the buttons. Turn TV off. Press and hold the OK button and at the same time press and HOLD the on/off switch for about 3 secs. You should get a self check screen that will last a little while and then the TV will go to the menu screen.
Sep 06, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
