Question about HP Office Equipment & Supplies
HP F2100 All in one series paper won't feed one sheet at a time. Still under warranty.
    Master:
  • 521 Answers
It is the problem of the gears below the paper feeder which pulls the paper they have to be cleaned or repaired, but if it is under warranty take it to the service center they will do it free of cost or can also give you the replacement for this.
Posted on Aug 08, 2008
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Stating that there is no paper but there is paper in the tray
Usually this means that the paper can't be picked up. First take out the paper and check for curled edges or wrinkled paper. Discard damaged pages. Check for torn corners and remove any small foreign objects. Make sure that the paper is aligned properly when you return the paper to the tray. If you only have a few sheets in the paper tray, add more paper.
Next check if the rollers are dirty. They can be cleaned with a damp lint-free cloth. (Just a little water is needed.) Check that the feed mechanism is undamaged. My home inkjet printer (an HP OfficeJet 7000) had a part of the paper lift mechanism break a few days ago. If you pushed the top sheet of paper just right, the printer would still pick it up. We noticed a loose piece when we opened the back of the printer for the straight-through paper feed. After attempting to replace that piece, we looked closer and another part fell out of the printer.
Some find it worthwhile to take apart the printer and re-attach the parts. If the printer is still under warranty, let HP do the job.
I hope this helps.
Sep 12, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Hp photosmart 5510
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. Once its done restart the Printer and try printing and let me know what happens.
Good Luck!!!
May 15, 2013 | HP PhotoSmart Office Equipment & Supplies
Photo paper jams
Feed only one sheet at a time and select the paper type properly in the menu. HP are notorious for paper jambs with thick paper because the paper path folds back on itself when using front loading trays. If the printer has a rear paper feed capability, use it to make the paper path straight. EPSONs do not jamb as much, but the ink is far more expensive. Reading the on-line instructional manual from the web-site may provide a paper settings solution and calling HP's toll-free number may help too.
Aug 27, 2012 | HP Deskjet 5400 Series
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper feed feeds more than 1 sheet at a time
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Apr 26, 2010 | HP LaserJet 6L Printer
HP laserjet 5000N - Paper jam under the cartridge every time try to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | HP LaserJet 5000n Printer
Won't function
Jan 02, 2009 | Office Equipment & Supplies
Printer will not grab paper
Check to make sure the paper sensor tab moves freely. You might try air dusting around the paper pick-up rollers to make sure the area is free from any accumulation of dust, dirt, or paper residue.
Nov 19, 2008 | Office Equipment & Supplies
Ben Johnson
